Sony Vaio VPCCW17FX Back Case
    1. Sony Vaio VPCCW17FX Back Case, Back case: step 1, image 1 of 1
      • Turn the laptop over and orient it as shown.
      Ask FixBot
    2. Sony Vaio VPCCW17FX Back Case: step 2, image 1 of 3 Sony Vaio VPCCW17FX Back Case: step 2, image 2 of 3 Sony Vaio VPCCW17FX Back Case: step 2, image 3 of 3
      • Remove the battery by pinching the two lock tabs towards the center.
      • Next, lift up on the battery to remove it.
      Ask FixBot
    3. Sony Vaio VPCCW17FX Back Case: step 3, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
      • Be sure to remove all screws, including those that are typically covered by the battery.
      Ask FixBot
    4. Sony Vaio VPCCW17FX Back Case: step 4, image 1 of 3 Sony Vaio VPCCW17FX Back Case: step 4, image 2 of 3 Sony Vaio VPCCW17FX Back Case: step 4, image 3 of 3
      • Now, remove the small covers from the back of the case.
      • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
      • Then, lift up on and remove these covers as shown in the third image.
      Ask FixBot
    5. Sony Vaio VPCCW17FX Back Case: step 5, image 1 of 3 Sony Vaio VPCCW17FX Back Case: step 5, image 2 of 3 Sony Vaio VPCCW17FX Back Case: step 5, image 3 of 3
      • Remove the hard drive.
      • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
      • Next, lift up and pull outwards to release the hard drive from its socket.
      Ask FixBot
    6. Sony Vaio VPCCW17FX Back Case: step 6, image 1 of 1
      • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
      Ask FixBot
    7. Sony Vaio VPCCW17FX Back Case: step 7, image 1 of 1
      • After proper removal of all necessary screws, gently lift up on the back case to remove it.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 68
All Time: 1,642
