Sony Vaio VGN-Z48GD SSDs Replacement
    1. Sony Vaio VGN-Z48GD SSDs Replacement, SSDs: step 1, image 1 of 1
      • Power off your laptop before starting.
      • Disconnect all external cables from the device.
      Ask FixBot
    2. Sony Vaio VGN-Z48GD SSDs Replacement: step 2, image 1 of 1
      • Flip the device over so that the battery is facing away from you.
      • Unlock the battery by using your finger to push the "Lock" latch to the right.
      • You will hear a soft click when the latch has been disengaged.
      Ask FixBot
    3. Sony Vaio VGN-Z48GD SSDs Replacement: step 3, image 1 of 1
      • Place your finger on the "Release" latch.
      • Slide the latch to the right and hold it.
      • Use your other hand to lift the battery from the groove.
      • Remove the battery.
      Ask FixBot
    4. Sony Vaio VGN-Z48GD SSDs Replacement: step 4, image 1 of 1
      • Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
      • Remove the RAM cover.
      • There is no need to remove the RAMs as they won't get in the way.
      Ask FixBot
    5. Sony Vaio VGN-Z48GD SSDs Replacement: step 5, image 1 of 2 Sony Vaio VGN-Z48GD SSDs Replacement: step 5, image 2 of 2
      • Remove the following eleven screws:
      • Five 13 mm Phillips #000 screws
      • Six 5 mm Phillips #000 screws
      Ask FixBot
    6. Sony Vaio VGN-Z48GD SSDs Replacement: step 6, image 1 of 1
      • Flip the device and open the lid so that the keyboard is facing upwards.
      • Use an opening tool to lift the keyboard assembly slightly.
      • Make sure you don't lift the keyboard assembly too much as there is a ribbon cable in between.
      Ask FixBot
    7. Sony Vaio VGN-Z48GD SSDs Replacement: step 7, image 1 of 1
      • Flip the keyboard assembly towards you.
      Ask FixBot
    8. Sony Vaio VGN-Z48GD SSDs Replacement: step 8, image 1 of 1
      • Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
      • Remove the keyboard assembly.
      Ask FixBot
    9. Sony Vaio VGN-Z48GD SSDs Replacement: step 9, image 1 of 1
      • Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
      Ask FixBot
    10. Sony Vaio VGN-Z48GD SSDs Replacement: step 10, image 1 of 2 Sony Vaio VGN-Z48GD SSDs Replacement: step 10, image 2 of 2
      • Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver.
      • Remove the SSD bracket.
      Ask FixBot
    11. Sony Vaio VGN-Z48GD SSDs Replacement: step 11, image 1 of 1
      • Flip the SSD bracket.
      • Use your hand to disconnect the uSATA connector on the right.
      Ask FixBot
    12. Sony Vaio VGN-Z48GD SSDs Replacement: step 12, image 1 of 1
      • Use your hand to disconnect the uSATA connector on the left.
      • Remove the uSATA ribbon cable.
      Ask FixBot
    13. Sony Vaio VGN-Z48GD SSDs Replacement: step 13, image 1 of 1
      • Remove two 2 mm Phillips #00 screws.
      Ask FixBot
    14. Sony Vaio VGN-Z48GD SSDs Replacement: step 14, image 1 of 1
      Ask FixBot
    15. Sony Vaio VGN-Z48GD SSDs Replacement: step 15, image 1 of 1
      • Take out the SSDs from the bracket.
      Ask FixBot
Vincent L
265 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 83
All Time: 1,883
