Sony Vaio VGN-SZ120P Memory Replacement
  1. Sony Vaio VGN-SZ120P Memory Replacement, Battery: step 1, image 1 of 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
    Ask FixBot
  2. Sony Vaio VGN-SZ120P Memory Replacement: step 2, image 1 of 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
    Ask FixBot
  3. Sony Vaio VGN-SZ120P Memory Replacement, Memory: step 3, image 1 of 2 Sony Vaio VGN-SZ120P Memory Replacement, Memory: step 3, image 2 of 2
    • Unscrew the two memory panel screws and set the panel aside.
    • Ignore the removal of the heatsink panel. This does not need to be removed for RAM module access.
    Ask FixBot
  4. Sony Vaio VGN-SZ120P Memory Replacement: step 4, image 1 of 3 Sony Vaio VGN-SZ120P Memory Replacement: step 4, image 2 of 3 Sony Vaio VGN-SZ120P Memory Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the film covering to reveal the memory module with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat this step for the other RAM module located directly above the memory module just removed.
    Ask FixBot
Ryan
160 Reputation
2 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
59 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 5,419
