Sony Vaio VGN-SR140E Screen Replacement
    1. Sony Vaio VGN-SR140E Screen Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over and orient it as shown in the figure.
      Ask FixBot
    2. Sony Vaio VGN-SR140E Screen Replacement: step 2, image 1 of 1
      • Slide the lock latch to the right to release the battery lock.
      • Slide and hold the release latch to the left.
      Ask FixBot
    3. Sony Vaio VGN-SR140E Screen Replacement: step 3, image 1 of 2 Sony Vaio VGN-SR140E Screen Replacement: step 3, image 2 of 2
      • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
      Ask FixBot
    1. Sony Vaio VGN-SR140E Screen Replacement, Screen: step 4, image 1 of 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: step 4, image 2 of 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: step 4, image 3 of 3
      • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
      • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
      Ask FixBot
    2. Sony Vaio VGN-SR140E Screen Replacement: step 5, image 1 of 1
      • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
      Ask FixBot
    3. Sony Vaio VGN-SR140E Screen Replacement: step 6, image 1 of 2 Sony Vaio VGN-SR140E Screen Replacement: step 6, image 2 of 2
      • Lift screen bezel up and off of the laptop.
      Ask FixBot
    4. Sony Vaio VGN-SR140E Screen Replacement: step 7, image 1 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 7, image 2 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 7, image 3 of 3
      • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
      • Lay the screen gently on the keyboard. This will reveal the screen's connector.
      Ask FixBot
    5. Sony Vaio VGN-SR140E Screen Replacement: step 8, image 1 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 8, image 2 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 8, image 3 of 3
      • Grasp the connector and gently pull it out.
      Ask FixBot
    6. Sony Vaio VGN-SR140E Screen Replacement: step 9, image 1 of 1
      • The screen can now be removed.
      Ask FixBot
Jeremy
735 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 35
All Time: 1,507
