Sony Vaio VGN-SR140E RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
85
All Time:
1,035
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The battery needs to removed before servicing or replacing any other component. The RAM is under a panel held on by two screws. The RAM is easy to remove once the panel is off.
Tools
    1. Sony Vaio VGN-SR140E RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over and orient it as shown in the figure.
      Ask FixBot
    2. Sony Vaio VGN-SR140E RAM Replacement: step 2, image 1 of 1
      • Slide the lock latch to the right to release the battery lock.
      • Slide and hold the release latch to the left.
      Ask FixBot
    3. Sony Vaio VGN-SR140E RAM Replacement: step 3, image 1 of 2 Sony Vaio VGN-SR140E RAM Replacement: step 3, image 2 of 2
      • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
      Ask FixBot
    1. Sony Vaio VGN-SR140E RAM Replacement, RAM: step 4, image 1 of 1
      • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
      Ask FixBot
    2. Sony Vaio VGN-SR140E RAM Replacement: step 5, image 1 of 2 Sony Vaio VGN-SR140E RAM Replacement: step 5, image 2 of 2
      • Lift the thin black plastic cover to access the RAM.
      Ask FixBot
    3. Sony Vaio VGN-SR140E RAM Replacement: step 6, image 1 of 2 Sony Vaio VGN-SR140E RAM Replacement: step 6, image 2 of 2
      • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
      Ask FixBot
    4. Sony Vaio VGN-SR140E RAM Replacement: step 7, image 1 of 3 Sony Vaio VGN-SR140E RAM Replacement: step 7, image 2 of 3 Sony Vaio VGN-SR140E RAM Replacement: step 7, image 3 of 3
      • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
      Ask FixBot
Jeremy
735 Reputation
4 Guides authored
1 Guide Comment
C'est trop cool
Joël Zanou - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 85
All Time: 1,035
