Sony Vaio VGN-S260 Fan Replacement
    1. Sony Vaio VGN-S260 Fan Replacement, Battery: step 1, image 1 of 3 Sony Vaio VGN-S260 Fan Replacement, Battery: step 1, image 2 of 3 Sony Vaio VGN-S260 Fan Replacement, Battery: step 1, image 3 of 3
      • Flip the laptop over so the Vaio logo is facing down.
      • Locate the battery at the top and Find the release and unlock slides on the battery.
      • Slide the unlock tab to the unlock position.
      • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 2, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 2, image 2 of 2
      • With the tabs still in the unlock position, slide the battery away from the main case.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Keyboard: step 3, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement, Keyboard: step 3, image 2 of 2
      • Flip the computer over so the Vaio logo is facedown.
      • Unscrew the 2 screws next to the battery.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 4, image 1 of 1
      • Flip the computer over again so the Vaio logo is face up.
      • Open the lid.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 5, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 5, image 2 of 2
      • Press down on the outer gray shell around the keyboard.
      • Use the spudger to gently lift keyboard.
      • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
      Ask FixBot
    4. Sony Vaio VGN-S260 Fan Replacement: step 6, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 6, image 2 of 2
      • Lift up lever underneath the ribbon to detach the keyboard.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Upper Casing: step 7, image 1 of 1
      • Remove memory/wireless compartment cover.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 8, image 1 of 3 Sony Vaio VGN-S260 Fan Replacement: step 8, image 2 of 3 Sony Vaio VGN-S260 Fan Replacement: step 8, image 3 of 3
      • Flip so the Vaio Logo is face down.
      • Locate and remove a total of 8 screws on the bottom.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 9, image 1 of 1
      • Find and remove 5 screws (they all have arrows next to them) from cover.
      Ask FixBot
    4. Sony Vaio VGN-S260 Fan Replacement: step 10, image 1 of 3 Sony Vaio VGN-S260 Fan Replacement: step 10, image 2 of 3 Sony Vaio VGN-S260 Fan Replacement: step 10, image 3 of 3
      • Flip the laptop over so the Vaio logo is face up.
      • Use the spudger to pop up the upper casing.
      • Do not lift too much as the upper casing is attached to wires underneath.
      • Remove the wires that are attaching the upper casing to the motherboard.
      Ask FixBot
    5. Sony Vaio VGN-S260 Fan Replacement: step 11, image 1 of 1
      • Remove the upper casing.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Optical Drive: step 12, image 1 of 1
      • Remove the screw holding the optical drive casing to the logic board.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 13, image 1 of 1
      • Locate ribbon connecting optical drive case to logic board.
      • Pop off the ribbon.
      • Remove the metal PC-Card cage.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 14, image 1 of 1
      • Remove the four screws holding the optical drive to the logic board.
      Ask FixBot
    4. Sony Vaio VGN-S260 Fan Replacement: step 15, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 15, image 2 of 2
      • Locate brown locking tab above optical drive.
      • Lift up on brown locking tab until ribbon is loose.
      • Gently slide out and remove the optical drive from the computer.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: step 16, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: step 16, image 2 of 2
      • Remove the blue ribbon from the Ethernet Circuit Board.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 17, image 1 of 1
      • Remove the screws near the Ethernet Port circuit board.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 18, image 1 of 1
      • Remove the screws for the second ethernet circuit board.
      Ask FixBot
    4. Sony Vaio VGN-S260 Fan Replacement: step 19, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 19, image 2 of 2
      • Remove the ethernet ports.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Hard Drive: step 20, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement, Hard Drive: step 20, image 2 of 2
      • Remove the screws holding the hard drive casing in place.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 21, image 1 of 1
      • Find orange ribbon that is connected to the hard drive.
      • Find the holder of the ribbon and pop the ribbon off from it.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 22, image 1 of 1
      • Remove the casing and the orange ribbon.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Power Adapter: step 23, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement, Power Adapter: step 23, image 2 of 2
      • Locate the yellow power adapter.
      • Follow its wire to white logic board connector.
      • Pull out the wire from white logic board connector.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 24, image 1 of 3 Sony Vaio VGN-S260 Fan Replacement: step 24, image 2 of 3 Sony Vaio VGN-S260 Fan Replacement: step 24, image 3 of 3
      • Locate the screws on the fan filter casing.
      • Remove these screws.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 25, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 25, image 2 of 2
      • Remove the screw next to the yellow power adapter.
      • Lift out power adapter and fan filter.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Motherboard: step 26, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement, Motherboard: step 26, image 2 of 2
      • Remove screws on the motherboard.
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 27, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 27, image 2 of 2
      • Remove the nut using a 5mm nut driver.
      • Using a magnetic screwdriver handle will also work as well.
      Ask FixBot
    3. Sony Vaio VGN-S260 Fan Replacement: step 28, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 28, image 2 of 2
      • Remove the LCD display ribbon with a nylon spudger.
      • This is difficult to remove.
      Ask FixBot
    4. Sony Vaio VGN-S260 Fan Replacement: step 29, image 1 of 3 Sony Vaio VGN-S260 Fan Replacement: step 29, image 2 of 3 Sony Vaio VGN-S260 Fan Replacement: step 29, image 3 of 3
      • Gently lift the motherboard from the laptop.
      • The motherboard will be attached to the network wireless chip, which is also attached to the base of the laptop.
      • Remove the chip by popping the tabs on the side.
      • Slide out the network card.
      • You are now free to take the motherboard away from the base.
      Ask FixBot
    1. Sony Vaio VGN-S260 Fan Replacement, Fan: step 30, image 1 of 1
      • Disconnect the fan wire from the logic board
      Ask FixBot
    2. Sony Vaio VGN-S260 Fan Replacement: step 31, image 1 of 2 Sony Vaio VGN-S260 Fan Replacement: step 31, image 2 of 2
      • Turn the logic board over and Locate the screws connecting the fan to the logic board
      • Gently remove the fan from the logic board
      Ask FixBot
2 other people completed this guide.
Jeffrey Bryan
570 Reputation
11 Guides authored
Cal Poly, Team 16-4, Maness Spring 2010 Member of Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 41
All Time: 8,791
