Up to 20% off select tools
Sony Vaio VGN-FS640 RAM Replacement
Views: 11K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
105
All Time:
11,285
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide helps users replace the RAM in the Sony Vaio VGN-FS640 laptop.
    1. Sony Vaio VGN-FS640 RAM Replacement, Battery: step 1, image 1 of 1
      • Lay the closed laptop on its screen so the bottom is facing towards you.
      Ask FixBot
    2. Sony Vaio VGN-FS640 RAM Replacement: step 2, image 1 of 1
      • Push both latches towards the center of the battery.
      Ask FixBot
    3. Sony Vaio VGN-FS640 RAM Replacement: step 3, image 1 of 2 Sony Vaio VGN-FS640 RAM Replacement: step 3, image 2 of 2
      • Revome the battery by pushing it away from the laptop.
      • Set the battery away from the laptop.
      Ask FixBot
    1. Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: step 4, image 1 of 2 Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: step 4, image 2 of 2
      • With the bottom of the laptop facing up, locate the RAM cover.
      • The RAM is covered by the panel with four columns of vents.
      • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
      Ask FixBot
    2. Sony Vaio VGN-FS640 RAM Replacement: step 5, image 1 of 3 Sony Vaio VGN-FS640 RAM Replacement: step 5, image 2 of 3 Sony Vaio VGN-FS640 RAM Replacement: step 5, image 3 of 3
      • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
      • Once the panel is out of its locked position, it can be lifted out without any resistance.
      Ask FixBot
    1. Sony Vaio VGN-FS640 RAM Replacement, RAM: step 6, image 1 of 3 Sony Vaio VGN-FS640 RAM Replacement, RAM: step 6, image 2 of 3 Sony Vaio VGN-FS640 RAM Replacement, RAM: step 6, image 3 of 3
      • To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
      • When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
      • Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
      Ask FixBot
    2. Sony Vaio VGN-FS640 RAM Replacement: step 7, image 1 of 1
      • To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
      • Insert the gold leads of the RAM into the connection at the same angle the original chip was raised at after the tabs were released.
      • There is a raised tab on the connection that mates with a slit in the RAM to ensure you do not put the chip in upside down.
      Ask FixBot
    3. Sony Vaio VGN-FS640 RAM Replacement: step 8, image 1 of 1
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
Michael Maravick
75 Reputation
2 Guides authored
Cal Poly, Team 24-32, Regan Spring 2010 Member of Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 105
All Time: 11,285
