Sony Vaio VGN-FS640 Hard Drive Replacement
Views: 11K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
95
All Time:
11,293
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the hard drive in your Sony Vaio VGN-FS640 laptop.
Tools
    1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Lay the closed laptop on its screen so the bottom is facing towards you.
      Ask FixBot
    2. Sony Vaio VGN-FS640 Hard Drive Replacement: step 2, image 1 of 1
      • Push both latches towards the center of the battery.
      Ask FixBot
    3. Sony Vaio VGN-FS640 Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio VGN-FS640 Hard Drive Replacement: step 3, image 2 of 2
      • Revome the battery by pushing it away from the laptop.
      • Set the battery away from the laptop.
      Ask FixBot
    1. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
      • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
      • Slide the cover until it is free from the laptop case.
      • Lift the cover to remove.
      Ask FixBot
    2. Sony Vaio VGN-FS640 Hard Drive Replacement: step 5, image 1 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement: step 5, image 2 of 3 Sony Vaio VGN-FS640 Hard Drive Replacement: step 5, image 3 of 3
      • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
      • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
      • The Hard Drive should now be disconnected.
      • Lift the drive out with the tab on the tray.
      Ask FixBot
2 other people completed this guide.
Matt McCarty
220 Reputation
2 Guides authored
Cal Poly, Team 24-32, Regan Spring 2010 Member of Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Members
96 Guides authored
1 Guide Comment
cant sign to recover my external hard drive
manivanan88 - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 95
All Time: 11,293
