Sony Vaio VGN-FS640 Fan Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: step 1, image 1 of 1
      • Turn off the laptop and disconnect any charging cables.
      • Flip the laptop over so that the Service Tag is shown at the top left corner.
      Ask FixBot
    2. Sony Vaio VGN-FS640 Fan Replacement: step 2, image 1 of 1
      • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
      Ask FixBot
    3. Sony Vaio VGN-FS640 Fan Replacement: step 3, image 1 of 1
      • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
      Ask FixBot
    4. Sony Vaio VGN-FS640 Fan Replacement: step 4, image 1 of 1
      • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
      Ask FixBot
    5. Sony Vaio VGN-FS640 Fan Replacement: step 5, image 1 of 1
      • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
      Ask FixBot
    6. Sony Vaio VGN-FS640 Fan Replacement: step 6, image 1 of 1
      • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
      Ask FixBot
    7. Sony Vaio VGN-FS640 Fan Replacement: step 7, image 1 of 1
      • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
      • Remove the battery by pressing inwards on the tabs on either side of the battery.
      Ask FixBot
    8. Sony Vaio VGN-FS640 Fan Replacement: step 8, image 1 of 1
      • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
      Ask FixBot
    9. Sony Vaio VGN-FS640 Fan Replacement: step 9, image 1 of 1
      • Remove the backplate of the laptop by pulling it away from the laptop.
      Ask FixBot
    1. Sony Vaio VGN-FS640 Fan Replacement, Fan: step 10, image 1 of 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: step 10, image 2 of 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: step 10, image 3 of 3
      • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
      Ask FixBot
    2. Sony Vaio VGN-FS640 Fan Replacement: step 11, image 1 of 2 Sony Vaio VGN-FS640 Fan Replacement: step 11, image 2 of 2
      • Remove the four screws securing the fan.
      Ask FixBot
    3. Sony Vaio VGN-FS640 Fan Replacement: step 12, image 1 of 2 Sony Vaio VGN-FS640 Fan Replacement: step 12, image 2 of 2
      • Gently lift out the fan.
      • Do not forcefully pull the fan away. This may damage the circuit board.
      Ask FixBot
    4. Sony Vaio VGN-FS640 Fan Replacement: step 13, image 1 of 2 Sony Vaio VGN-FS640 Fan Replacement: step 13, image 2 of 2
      • Gently disconnect the remaining wire connecting the fan to the circuit board.
      • Remove the fan from the laptop.
      Ask FixBot
Geoffrey
252 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 111
All Time: 1,148
