Up to 20% off select tools
Sony Vaio Tap 11 Wifi Module Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
122
All Time:
3,063
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Sony Vaio Tap 11 Wifi Module Replacement, Screen Assembly: step 1, image 1 of 1
      • Begin by opening the HDMI/USB port cover on the left edge.
      • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
      Ask FixBot
    2. Sony Vaio Tap 11 Wifi Module Replacement: step 2, image 1 of 1
      • Locate and open the Micro SD slot on the top side of the device.
      • Remove the two screws located beneath the cover.
      Ask FixBot
    3. Sony Vaio Tap 11 Wifi Module Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Wifi Module Replacement: step 3, image 2 of 2
      • Attach the suction cup to the top right area of the screen.
      • Pull to separate the screen from the rest of the device.
      • Be aware of the front camera cable that is still connected to the rest of the device.
      • Detach the display ribbon cable.
      Ask FixBot
    1. Sony Vaio Tap 11 Wifi Module Replacement, Solid State Disk: step 4, image 1 of 1
      • Unplug the battery connector located beside the fan.
      • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
      Ask FixBot
    2. Sony Vaio Tap 11 Wifi Module Replacement: step 5, image 1 of 1
      • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
      Ask FixBot
    3. Sony Vaio Tap 11 Wifi Module Replacement: step 6, image 1 of 2 Sony Vaio Tap 11 Wifi Module Replacement: step 6, image 2 of 2
      • Pull the SSD towards the right and slightly up, removing it from the back assembly.
      Ask FixBot
    1. Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: step 7, image 1 of 3 Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: step 7, image 2 of 3 Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: step 7, image 3 of 3
      • Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
      • Gently tug either side until it releases, then pull out the other end.
      Ask FixBot
    2. Sony Vaio Tap 11 Wifi Module Replacement: step 8, image 1 of 1
      • Remove the grey foam separator that was underneath the orange ribbon cable.
      Ask FixBot
    3. Sony Vaio Tap 11 Wifi Module Replacement: step 9, image 1 of 1
      • Remove the silver 3 mm Phillips screw that holds the WiFi module in place.
      Ask FixBot
    4. Sony Vaio Tap 11 Wifi Module Replacement: step 10, image 1 of 1
      • Remove the black and grey antenna cables from the right side of the device.
      Ask FixBot
    5. Sony Vaio Tap 11 Wifi Module Replacement: step 11, image 1 of 1
      • Remove module by gently pulling towards the right.
      Ask FixBot
2 other people completed this guide.
Author
with
Alexander Bridges
1,241 Reputation
7 Guides authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 122
All Time: 3,063
