Up to 20% off select tools
Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
104
All Time:
1,691
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
With this guide, you will be taking the screen off of the device to locate the camera module. The following steps will explain how to remove the necessary parts in order to remove the camera module located on your screen.
    1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: step 1, image 1 of 1
      • Begin by opening the HDMI/USB port cover on the left edge.
      • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
      Ask FixBot
    2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: step 2, image 1 of 1
      • Locate and open the Micro SD slot on the top side of the device.
      • Remove the two screws located beneath the cover.
      Ask FixBot
    3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: step 3, image 2 of 2
      • Attach the suction cup to the top right area of the screen.
      • Pull to separate the screen from the rest of the device.
      • Be aware of the front camera cable that is still connected to the rest of the device.
      • Detach the display ribbon cable.
      Ask FixBot
    1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: step 4, image 1 of 1
      • Flip device upward carefully like you are turning the page of a book.
      Ask FixBot
    2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: step 5, image 1 of 1
      • Disconnect the camera cable from the device backing.
      Ask FixBot
    3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: step 6, image 1 of 1
      • Remove the single 3 mm Phillips #000 screw on the left side of the module.
      • Remove the module from the front panel assembly.
      Ask FixBot
Author
with
Nick Catanzarite
188 Reputation
1 Guide authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
120 Guides authored
1 Guide Comment
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 104
All Time: 1,691
