Sony Vaio Tap 11 Power Jack Replacement
    1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: step 1, image 1 of 1
      • Begin by opening the HDMI/USB port cover on the left edge.
      • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
      Ask FixBot
    2. Sony Vaio Tap 11 Power Jack Replacement: step 2, image 1 of 1
      • Locate and open the Micro SD slot on the top side of the device.
      • Remove the two screws located beneath the cover.
      Ask FixBot
    3. Sony Vaio Tap 11 Power Jack Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Power Jack Replacement: step 3, image 2 of 2
      • Attach the suction cup to the top right area of the screen.
      • Pull to separate the screen from the rest of the device.
      • Be aware of the front camera cable that is still connected to the rest of the device.
      • Detach the display ribbon cable.
      Ask FixBot
    1. Sony Vaio Tap 11 Power Jack Replacement, Battery: step 4, image 1 of 1
      • Disconnect the battery from the motherboard by pulling out the cable below the fan.
      Ask FixBot
    2. Sony Vaio Tap 11 Power Jack Replacement: step 5, image 1 of 1
      • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
      • Carefully remove the battery from the back assembly.
      Ask FixBot
    1. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: step 6, image 1 of 1
      • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
      Ask FixBot
    2. Sony Vaio Tap 11 Power Jack Replacement: step 7, image 1 of 1
      • Unplug the jack from the motherboard.
      Ask FixBot
    3. Sony Vaio Tap 11 Power Jack Replacement: step 8, image 1 of 1
      • Remove the metal covering.
      Ask FixBot
    4. Sony Vaio Tap 11 Power Jack Replacement: step 9, image 1 of 1
      • Pull out the cable and jack assembly.
      Ask FixBot
3 other people completed this guide.
Alexander Bridges
1,241 Reputation
7 Guides authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
120 Guides authored
2 Guide Comments
I wonder if you have the part number or can supply this power jack?
James Toal - Reply Share
Yes, Where can I find this replacement part?
mikebeard65 - Reply Share
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 120
All Time: 2,600
