Sony Vaio Tap 11 Battery Replacement
    1. Sony Vaio Tap 11 Battery Replacement, Screen Assembly: step 1, image 1 of 1
      • Begin by opening the HDMI/USB port cover on the left edge.
      • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
      Ask FixBot
    2. Sony Vaio Tap 11 Battery Replacement: step 2, image 1 of 1
      • Locate and open the Micro SD slot on the top side of the device.
      • Remove the two screws located beneath the cover.
      Ask FixBot
    3. Sony Vaio Tap 11 Battery Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Battery Replacement: step 3, image 2 of 2
      • Attach the suction cup to the top right area of the screen.
      • Pull to separate the screen from the rest of the device.
      • Be aware of the front camera cable that is still connected to the rest of the device.
      • Detach the display ribbon cable.
      Ask FixBot
    1. Sony Vaio Tap 11 Battery Replacement, Battery: step 4, image 1 of 1
      • Disconnect the battery from the motherboard by pulling out the cable below the fan.
      Ask FixBot
    2. Sony Vaio Tap 11 Battery Replacement: step 5, image 1 of 1
      • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
      • Carefully remove the battery from the back assembly.
      Ask FixBot
3 other people completed this guide.
Alexander Bridges
1,241 Reputation
7 Guides authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 43
Past 30 Days: 146
All Time: 7,191
