Sony Vaio SVT151A11L USB Port Board Replacement
    1. Sony Vaio SVT151A11L USB Port Board Replacement, Battery: step 1, image 1 of 2 Sony Vaio SVT151A11L USB Port Board Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over so that the battery on the underside of the device is revealed.
      • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
      Ask FixBot
    2. Sony Vaio SVT151A11L USB Port Board Replacement: step 2, image 1 of 3 Sony Vaio SVT151A11L USB Port Board Replacement: step 2, image 2 of 3 Sony Vaio SVT151A11L USB Port Board Replacement: step 2, image 3 of 3
      • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
      • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
      • Grab the battery and remove it from the device.
      Ask FixBot
    1. Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: step 3, image 1 of 3 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: step 3, image 2 of 3 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: step 3, image 3 of 3
      • Unscrew the three 4mm screws using a JIS #0 screwdriver.
      • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
      • Grab and lift the edge of the panel to pull it free from the rest of the computer.
      Ask FixBot
    2. Sony Vaio SVT151A11L USB Port Board Replacement: step 4, image 1 of 3 Sony Vaio SVT151A11L USB Port Board Replacement: step 4, image 2 of 3 Sony Vaio SVT151A11L USB Port Board Replacement: step 4, image 3 of 3
      • Grab the disk drive located at the edge of the computer and pull it it out.
      • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
      Ask FixBot
    1. Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: step 5, image 1 of 2 Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: step 5, image 2 of 2
      • Use a JIS #0 screwdriver to unscrew the two 4mm screws from the board.
      Ask FixBot
    2. Sony Vaio SVT151A11L USB Port Board Replacement: step 6, image 1 of 3 Sony Vaio SVT151A11L USB Port Board Replacement: step 6, image 2 of 3 Sony Vaio SVT151A11L USB Port Board Replacement: step 6, image 3 of 3
      • Lift board and peel the ribbon cable from the computer.
      • Lift and pull the end of the ribbon cable to remove it from the slot.
      Ask FixBot
Nathan McGarvey
487 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,458
