Sony Vaio SVF15A16CXB RAM Replacement
    1. Sony Vaio SVF15A16CXB RAM Replacement, Back Panel: step 1, image 1 of 1
      • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
      • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
      • 6 mm screws marked in red, 4 mm marked in orange
      Ask FixBot
    2. Sony Vaio SVF15A16CXB RAM Replacement: step 2, image 1 of 2 Sony Vaio SVF15A16CXB RAM Replacement: step 2, image 2 of 2
      • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
      • In reassembly, slide the optical drive back in after reapplying cover.
      Ask FixBot
    3. Sony Vaio SVF15A16CXB RAM Replacement: step 3, image 1 of 1
      • Run the opening tool along the bottom cover seam.
      Ask FixBot
    4. Sony Vaio SVF15A16CXB RAM Replacement: step 4, image 1 of 1
      • Lift the clip marked in red in order to release the back cover.
      • Lift the back cover.
      Ask FixBot
    1. Sony Vaio SVF15A16CXB RAM Replacement, RAM: step 5, image 1 of 1
      • Locate the two metal clips securing the RAM.
      Ask FixBot
    2. Sony Vaio SVF15A16CXB RAM Replacement: step 6, image 1 of 1
      • Pull apart the two metal clips with your fingers.
      • Once you pull the metal clips away, the RAM will spring up from its original position.
      Ask FixBot
    3. Sony Vaio SVF15A16CXB RAM Replacement: step 7, image 1 of 1
      • Pull the RAM out of the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,043
