Sony Vaio SVF15A16CXB Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
63
All Time:
926
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide helps users to remove a fan, which leads the user of the steps to remove and replace the fan of the laptop.
Tools
    1. Sony Vaio SVF15A16CXB Fan  Replacement, Back Panel: step 1, image 1 of 1
      • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
      • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
      • 6 mm screws marked in red, 4 mm marked in orange
      Ask FixBot
    2. Sony Vaio SVF15A16CXB Fan  Replacement: step 2, image 1 of 2 Sony Vaio SVF15A16CXB Fan  Replacement: step 2, image 2 of 2
      • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
      • In reassembly, slide the optical drive back in after reapplying cover.
      Ask FixBot
    3. Sony Vaio SVF15A16CXB Fan  Replacement: step 3, image 1 of 1
      • Run the opening tool along the bottom cover seam.
      Ask FixBot
    4. Sony Vaio SVF15A16CXB Fan  Replacement: step 4, image 1 of 1
      • Lift the clip marked in red in order to release the back cover.
      • Lift the back cover.
      Ask FixBot
    1. Sony Vaio SVF15A16CXB Fan  Replacement, Fan: step 5, image 1 of 1
      • Unplug the clip (red black yellow wires) by pulling it in an upward direction.
      Ask FixBot
    2. Sony Vaio SVF15A16CXB Fan  Replacement: step 6, image 1 of 1
      • Remove two 4mm screws on the left side of the circular fan.
      • Both of these screws have a white washer attached.
      Ask FixBot
    3. Sony Vaio SVF15A16CXB Fan  Replacement: step 7, image 1 of 1
      • Unscrew the four 4mm screws from the connecting copper piece. The two screws are located on either side of the copper piece.
      • The 4 mm screws won’t come out but the fan will, the screws are just to hold the fan in place.
      Ask FixBot
    4. Sony Vaio SVF15A16CXB Fan  Replacement: step 8, image 1 of 2 Sony Vaio SVF15A16CXB Fan  Replacement: step 8, image 2 of 2
      • Gently pull off the fan from the motherboard.
      Ask FixBot
qiuhong Li
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 63
All Time: 926
