Sony Vaio SVF15A16CXB Back Panel Replacement
    1. Sony Vaio SVF15A16CXB Back Panel  Replacement, Back Panel: step 1, image 1 of 1
      • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
      • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
      • 6 mm screws marked in red, 4 mm marked in orange
      Ask FixBot
    2. Sony Vaio SVF15A16CXB Back Panel  Replacement: step 2, image 1 of 2 Sony Vaio SVF15A16CXB Back Panel  Replacement: step 2, image 2 of 2
      • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
      • In reassembly, slide the optical drive back in after reapplying cover.
      Ask FixBot
    3. Sony Vaio SVF15A16CXB Back Panel  Replacement: step 3, image 1 of 1
      • Run the opening tool along the bottom cover seam.
      Ask FixBot
    4. Sony Vaio SVF15A16CXB Back Panel  Replacement: step 4, image 1 of 1
      • Lift the clip marked in red in order to release the back cover.
      • Lift the back cover.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 79
All Time: 1,841
