Sony Vaio SVE151G11L Motherboard Replacement
    1. Sony Vaio SVE151G11L Motherboard Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so its underside is facing upwards and visible.
      Ask FixBot
    2. Sony Vaio SVE151G11L Motherboard Replacement: step 2, image 1 of 1
      • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
      Ask FixBot
    3. Sony Vaio SVE151G11L Motherboard Replacement: step 3, image 1 of 1
      • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
      Ask FixBot
    4. Sony Vaio SVE151G11L Motherboard Replacement: step 4, image 1 of 1
      • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
      Ask FixBot
    5. Sony Vaio SVE151G11L Motherboard Replacement: step 5, image 1 of 1
      • Pull battery away from laptop.
      Ask FixBot
    1. Sony Vaio SVE151G11L Motherboard Replacement, Hard Disk Drive: step 6, image 1 of 1
      • Flip laptop over so the bottom is facing upwards.
      Ask FixBot
    2. Sony Vaio SVE151G11L Motherboard Replacement: step 7, image 1 of 1
      • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
      Ask FixBot
    3. Sony Vaio SVE151G11L Motherboard Replacement: step 8, image 1 of 2 Sony Vaio SVE151G11L Motherboard Replacement: step 8, image 2 of 2
      • Pop open the cover to the HDD.
      Ask FixBot
    4. Sony Vaio SVE151G11L Motherboard Replacement: step 9, image 1 of 1
      • Remove the screws on the HDD with a Phillips #000 screwdriver.
      Ask FixBot
    5. Sony Vaio SVE151G11L Motherboard Replacement: step 10, image 1 of 2 Sony Vaio SVE151G11L Motherboard Replacement: step 10, image 2 of 2
      • Pull plastic tab away from the laptop.
      • Lift HDD away from laptop.
      Ask FixBot
    1. Sony Vaio SVE151G11L Motherboard Replacement, Motherboard: step 11, image 1 of 1
      • Flip the laptop over on its backside.
      Ask FixBot
    2. Sony Vaio SVE151G11L Motherboard Replacement: step 12, image 1 of 1
      • Remove the screws holding the motherboard in place.
      Ask FixBot
    3. Sony Vaio SVE151G11L Motherboard Replacement: step 13, image 1 of 2 Sony Vaio SVE151G11L Motherboard Replacement: step 13, image 2 of 2
      • Pop the motherboard away from the frame.
      Ask FixBot
    4. Sony Vaio SVE151G11L Motherboard Replacement: step 14, image 1 of 1
      • Remove the ribbon cable from the motherboard.
      Ask FixBot
    5. Sony Vaio SVE151G11L Motherboard Replacement: step 15, image 1 of 2 Sony Vaio SVE151G11L Motherboard Replacement: step 15, image 2 of 2
      • Remove motherboard from the laptop.
      Ask FixBot
2 other people completed this guide.
Alex Theg
761 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 2,580
