Sony Vaio SVE15112FXS Fan Replacement
    1. Sony Vaio SVE15112FXS Fan Replacement, Fan: step 1, image 1 of 1
      • Power laptop off before beginning.
      • Turn the laptop over so that it is positioned top down with the model number facing you.
      Ask FixBot
    2. Sony Vaio SVE15112FXS Fan Replacement: step 2, image 1 of 1
      • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
      • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
      Ask FixBot
    3. Sony Vaio SVE15112FXS Fan Replacement: step 3, image 1 of 2 Sony Vaio SVE15112FXS Fan Replacement: step 3, image 2 of 2
      • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
      Ask FixBot
    4. Sony Vaio SVE15112FXS Fan Replacement: step 4, image 1 of 1
      • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
      Ask FixBot
    5. Sony Vaio SVE15112FXS Fan Replacement: step 5, image 1 of 2 Sony Vaio SVE15112FXS Fan Replacement: step 5, image 2 of 2
      • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
      • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
      • Lift the hard drive out of the well.
      Ask FixBot
    6. Sony Vaio SVE15112FXS Fan Replacement: step 6, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the one 4.0 mm screw next to the model number label.
      Ask FixBot
    7. Sony Vaio SVE15112FXS Fan Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to slide the CD-ROM out from the laptop.
      Ask FixBot
    8. Sony Vaio SVE15112FXS Fan Replacement: step 8, image 1 of 3 Sony Vaio SVE15112FXS Fan Replacement: step 8, image 2 of 3 Sony Vaio SVE15112FXS Fan Replacement: step 8, image 3 of 3
      • Slide the "lock" tab upward to unlock the battery before removal.
      • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
      Ask FixBot
    9. Sony Vaio SVE15112FXS Fan Replacement: step 9, image 1 of 3 Sony Vaio SVE15112FXS Fan Replacement: step 9, image 2 of 3 Sony Vaio SVE15112FXS Fan Replacement: step 9, image 3 of 3
      • To unsecure the bottom cover, remove all the cover screws using a #0 Phillips screwdriver.
      • Remove the two 9.0 mm screws on each side of the battery.
      • Remove the twelve 8.0 mm long screws alongside the entire back cover.
      • Remove the three 3.0 mm screws inside the battery well.
      Ask FixBot
    10. Sony Vaio SVE15112FXS Fan Replacement: step 10, image 1 of 3 Sony Vaio SVE15112FXS Fan Replacement: step 10, image 2 of 3 Sony Vaio SVE15112FXS Fan Replacement: step 10, image 3 of 3
      • Use a plastic opening tool to carefully pry open the latch points located under the silver plastic trim. Repeat this around the back cover.
      • It may be easiest to start around the CD-ROM bay because there is more room.
      • To avoid damaging the plastic trim and cover, do not force difficult areas and make sure the opening tool is completely under the black plastic cover, not just the silver trim.
      • Lift the back cover upward and away from the laptop.
      Ask FixBot
    11. Sony Vaio SVE15112FXS Fan Replacement: step 11, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 3.0 mm screws attaching the fan to the heat sink unit.
      Ask FixBot
    12. Sony Vaio SVE15112FXS Fan Replacement: step 12, image 1 of 2 Sony Vaio SVE15112FXS Fan Replacement: step 12, image 2 of 2
      • Use a plastic opening tool to unsecure the white power cable connector.
      • Do not pull on the wires as this could rip them from the cable connector.
      • Carefully unwrap the red and yellow wires from the hooks.
      • Take note of how the wires are wrapped around the hooks.
      Ask FixBot
    13. Sony Vaio SVE15112FXS Fan Replacement: step 13, image 1 of 1
      • Lift the fan upward to remove it from the heat sink unit.
      Ask FixBot
Ashley Bierman
1,301 Reputation
5 Guides authored
Ohio State, Team S1-G1, Whitney Fall 2018 Member of Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 33
All Time: 967
