Up to 20% off select tools
Sony Vaio SVE111B11L Screen Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
87
All Time:
2,084
Comments: 3
3 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the screen of a Sony Vaio SVE111B11L. This repair may be needed if the screen melts or cracks. To replace the screen follow the guide in reverse order.
    1. Sony Vaio SVE111B11L  Screen Replacement, Battery: step 1, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement, Battery: step 1, image 2 of 2
      • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
      • Locate the battery on the bottom of the computer.
      • Flip the computer so that the battery faces you.
      Ask FixBot
    2. Sony Vaio SVE111B11L  Screen Replacement: step 2, image 1 of 1
      • Locate the two latches with the words “lock” and “release” on them.
      Ask FixBot
    3. Sony Vaio SVE111B11L  Screen Replacement: step 3, image 1 of 1
      • Push the latches towards each other and lift the battery to remove it.
      Ask FixBot
    1. Sony Vaio SVE111B11L  Screen Replacement, Keyboard Assembly: step 4, image 1 of 1
      • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
      • The screws for the memory door do not come out.
      Ask FixBot
    2. Sony Vaio SVE111B11L  Screen Replacement: step 5, image 1 of 1
      • Remove the 6.7 mm screw that holds the keyboard assembly in place.
      Ask FixBot
    3. Sony Vaio SVE111B11L  Screen Replacement: step 6, image 1 of 1
      • Be careful not to break the keyboard wire connection.
      • Slide the wires out, away from the solder connections.
      • Flip the computer over and open it.
      Ask FixBot
    4. Sony Vaio SVE111B11L  Screen Replacement: step 7, image 1 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 7, image 2 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 7, image 3 of 3
      • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
      • Using an opening tool, gently pull out and slightly up on the connector clip.
      • Gently lift the keyboard assembly up and out.
      Ask FixBot
    1. Sony Vaio SVE111B11L  Screen Replacement, Motherboard: step 8, image 1 of 1
      • Remove charging adaptor. Some charge may still be in the battery or computer.
      • DO NOT touch connectors or copper yellow connector.
      • Take the covers on the bottom of the laptop off.
      Ask FixBot
    2. Sony Vaio SVE111B11L  Screen Replacement: step 9, image 1 of 1
      • Locate and remove the screws holding the motherboard down.
      • Screws: L 4.6mm X D 1.85mm
      Ask FixBot
    3. Sony Vaio SVE111B11L  Screen Replacement: step 10, image 1 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 10, image 2 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 10, image 3 of 3
      • Locate the wires and connectors and remove them from the motherboard.
      Ask FixBot
    4. Sony Vaio SVE111B11L  Screen Replacement: step 11, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement: step 11, image 2 of 2
      • Lift the mother board out and safely put it to the side.
      Ask FixBot
    1. Sony Vaio SVE111B11L  Screen Replacement, Screen: step 12, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement, Screen: step 12, image 2 of 2
      • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
      • Locate screws. L 3.35mm X D 1.8mm
      • Remove Screws.
      • Lay the screen on a hard flat surface.
      • Remove hinges and wires for ease of removal.
      Ask FixBot
    2. Sony Vaio SVE111B11L  Screen Replacement: step 13, image 1 of 1
      • Gently remove the screen cover.
      • Be careful of the camera at the top of the screen.
      • Be careful of the seal tape between the cover and the screen.
      Ask FixBot
    3. Sony Vaio SVE111B11L  Screen Replacement: step 14, image 1 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 14, image 2 of 3 Sony Vaio SVE111B11L  Screen Replacement: step 14, image 3 of 3
      • Locate the wires and connectors.
      • Unplug the wires from the connectors.
      • Be careful of the yellow tape around the connection.
      Ask FixBot
    4. Sony Vaio SVE111B11L  Screen Replacement: step 15, image 1 of 2 Sony Vaio SVE111B11L  Screen Replacement: step 15, image 2 of 2
      • Gently lift the screen assembly up and out.
      Ask FixBot
2 other people completed this guide.
Author
with
John Noll
819 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 87
All Time: 2,084
