Sony Vaio Pro 13 Bottom Cover Replacement
    1. Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
      • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
      • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
      Ask FixBot
    2. Sony Vaio Pro 13 Bottom Cover Replacement: step 2, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement: step 2, image 2 of 2
      • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
      • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
      Ask FixBot
    3. Sony Vaio Pro 13 Bottom Cover Replacement: step 3, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
      • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
      Ask FixBot
7 other people completed this guide.
1 Guide Comment
Hi…I have same laptop, what your advice getting the cover back on? especially near the audio and usb ports…that my hang up
thanks
chrisrai - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 115
All Time: 7,975
