Sony Vaio PCG-F420 Keyboard Replacement
    1. Sony Vaio PCG-F420 Keyboard Replacement, Battery: step 1, image 1 of 1
      • The battery is located on the left side of the laptop, as shown by the red circle.
      • Make sure the laptop is disconnected and turned completely off.
      Ask FixBot
    2. Sony Vaio PCG-F420 Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery by following these steps.
      • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
      • The battery can now be removed by pulling it.
      Ask FixBot
    1. Sony Vaio PCG-F420 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
      Ask FixBot
    2. Sony Vaio PCG-F420 Keyboard Replacement: step 4, image 1 of 1
      • Unlock the cover between the keyboard and screen.
      • Gently slide it to the right and lift it up.
      • Exercise caution to avoid excessive force, as wires are connected.
      • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
      Ask FixBot
    3. Sony Vaio PCG-F420 Keyboard Replacement: step 5, image 1 of 1
      • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
      • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
      Ask FixBot
    4. Sony Vaio PCG-F420 Keyboard Replacement: step 6, image 1 of 1
      • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
      Ask FixBot
    5. Sony Vaio PCG-F420 Keyboard Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully unplug the ribbon cable using a pair of tweezers.
      • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
      Ask FixBot
    6. Sony Vaio PCG-F420 Keyboard Replacement: step 8, image 1 of 2 Sony Vaio PCG-F420 Keyboard Replacement: step 8, image 2 of 2
      • Now, pull on the ribbon cable, and it will detach from the motherboard.
      • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
      Ask FixBot
    7. Sony Vaio PCG-F420 Keyboard Replacement: step 9, image 1 of 1
      • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
      Ask FixBot
Andrew Quayle
44 Reputation
2 Guides authored
Cal Poly, Team 29-77, Johann Spring 2010 Member of Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 110
All Time: 3,123
