Sony Vaio PCG-F360 Optical Drive Replacement
    1. Sony Vaio PCG-F360 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Position the laptop screen-side down as shown.
      • In this position the battery housing will be located on the right hand side.
      Ask FixBot
    2. Sony Vaio PCG-F360 Optical Drive Replacement: step 2, image 1 of 1
      • Lift the panel up and then out to gain access to the battery.
      Ask FixBot
    3. Sony Vaio PCG-F360 Optical Drive Replacement: step 3, image 1 of 1
      • Use the indentations to pull the old battery out.
      Ask FixBot
    4. Sony Vaio PCG-F360 Optical Drive Replacement: step 4, image 1 of 1
      • The battery is now removed and it is safe to move on to uninstalling other components.
      Ask FixBot
    1. Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: step 5, image 1 of 3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: step 5, image 2 of 3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: step 5, image 3 of 3
      • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
      • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
      • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
      Ask FixBot
    2. Sony Vaio PCG-F360 Optical Drive Replacement: step 6, image 1 of 3 Sony Vaio PCG-F360 Optical Drive Replacement: step 6, image 2 of 3 Sony Vaio PCG-F360 Optical Drive Replacement: step 6, image 3 of 3
      • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
      • Remove the ribbon by gently pulling on it, there should be little or no resistance.
      • Now the speaker panel can be set aside.
      Ask FixBot
    3. Sony Vaio PCG-F360 Optical Drive Replacement: step 7, image 1 of 2 Sony Vaio PCG-F360 Optical Drive Replacement: step 7, image 2 of 2
      • Remove the metal screw that will be located at the red circle.
      • Pull on the green strip, and the keyboard should come free easily.
      Ask FixBot
    1. Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: step 8, image 1 of 2 Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: step 8, image 2 of 2
      • Remove the three screws surrounding the fan.
      • Take off the guard that you just unscrewed.
      • Carefully flip over the heat pipe and the metal sheet connected to it.
      Ask FixBot
    2. Sony Vaio PCG-F360 Optical Drive Replacement: step 9, image 1 of 3 Sony Vaio PCG-F360 Optical Drive Replacement: step 9, image 2 of 3 Sony Vaio PCG-F360 Optical Drive Replacement: step 9, image 3 of 3
      • Remove the three screws from the heat tube cover.
      • Carefully remove the cover.
      Ask FixBot
    3. Sony Vaio PCG-F360 Optical Drive Replacement: step 10, image 1 of 2 Sony Vaio PCG-F360 Optical Drive Replacement: step 10, image 2 of 2
      • Use a spudger to pry the ribbon connected to the optical drive.
      • Slide the optical drive free of the enclosure.
      Ask FixBot
ahintz
28 Reputation
8 Guides authored
Cal Poly, Team 16-3, Maness Spring 2010 Member of Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 29
All Time: 2,237
