Up to 20% off select tools
Sony Vaio PCG-F360 Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
21
All Time:
1,912
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In order to remove the inner components, you must first remove the keyboard. The keyboard can also be replaced.
    1. Sony Vaio PCG-F360 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Position the laptop screen-side down as shown.
      • In this position the battery housing will be located on the right hand side.
      Ask FixBot
    2. Sony Vaio PCG-F360 Keyboard Replacement: step 2, image 1 of 1
      • Lift the panel up and then out to gain access to the battery.
      Ask FixBot
    3. Sony Vaio PCG-F360 Keyboard Replacement: step 3, image 1 of 1
      • Use the indentations to pull the old battery out.
      Ask FixBot
    4. Sony Vaio PCG-F360 Keyboard Replacement: step 4, image 1 of 1
      • The battery is now removed and it is safe to move on to uninstalling other components.
      Ask FixBot
    1. Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Sony Vaio PCG-F360 Keyboard Replacement, Keyboard: step 5, image 3 of 3
      • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
      • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
      • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
      Ask FixBot
    2. Sony Vaio PCG-F360 Keyboard Replacement: step 6, image 1 of 3 Sony Vaio PCG-F360 Keyboard Replacement: step 6, image 2 of 3 Sony Vaio PCG-F360 Keyboard Replacement: step 6, image 3 of 3
      • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
      • Remove the ribbon by gently pulling on it, there should be little or no resistance.
      • Now the speaker panel can be set aside.
      Ask FixBot
    3. Sony Vaio PCG-F360 Keyboard Replacement: step 7, image 1 of 2 Sony Vaio PCG-F360 Keyboard Replacement: step 7, image 2 of 2
      • Remove the metal screw that will be located at the red circle.
      • Pull on the green strip, and the keyboard should come free easily.
      Ask FixBot
Author
with
ahintz
28 Reputation
8 Guides authored
Cal Poly, Team 16-3, Maness Spring 2010 Member of Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,912
