Sony Vaio PCG-F360 Floppy Drive Replacement
    1. Sony Vaio PCG-F360 Floppy Drive Replacement, Battery: step 1, image 1 of 1
      • Position the laptop screen-side down as shown.
      • In this position the battery housing will be located on the right hand side.
      Ask FixBot
    2. Sony Vaio PCG-F360 Floppy Drive Replacement: step 2, image 1 of 1
      • Lift the panel up and then out to gain access to the battery.
      Ask FixBot
    3. Sony Vaio PCG-F360 Floppy Drive Replacement: step 3, image 1 of 1
      • Use the indentations to pull the old battery out.
      Ask FixBot
    4. Sony Vaio PCG-F360 Floppy Drive Replacement: step 4, image 1 of 1
      • The battery is now removed and it is safe to move on to uninstalling other components.
      Ask FixBot
    1. Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: step 5, image 1 of 2 Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: step 5, image 2 of 2
      • With one hand slide and hold the tab shown.
      • With your other hand, pull the floppy drive out of the floppy drive bay.
      • To replace the floppy drive, simply slide the drive into the slot until it clicks.
      Ask FixBot
ahintz
28 Reputation
8 Guides authored
Cal Poly, Team 16-3, Maness Spring 2010 Member of Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 37
All Time: 3,286
