Sony Vaio PCG-981L Floppy Drive Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
28
All Time:
3,198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If for any reason the floppy drive isn't working, the simplest solution is to replace the entire drive. But, if you're not able to acquire a new drive you may be able at least find the source of the failure through disassembling the drive.
Tools
    1. Sony Vaio PCG-981L Floppy Drive Replacement, Floppy Drive: step 1, image 1 of 1
      • Turn the device over so that its underside is facing up. Then, slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
      Ask FixBot
    2. Sony Vaio PCG-981L Floppy Drive Replacement: step 2, image 1 of 1
      • Remove the floppy drive from the laptop.
      Ask FixBot
    3. Sony Vaio PCG-981L Floppy Drive Replacement: step 3, image 1 of 1
      • There are two screws on each side of the floppy drive (four screws total). Remove these screws.
      Ask FixBot
    4. Sony Vaio PCG-981L Floppy Drive Replacement: step 4, image 1 of 1
      • Remove the floppy drive core from its casing.
      Ask FixBot
    5. Sony Vaio PCG-981L Floppy Drive Replacement: step 5, image 1 of 1
      • Unscrew the five screws from the back of the optical drive.
      Ask FixBot
    6. Sony Vaio PCG-981L Floppy Drive Replacement: step 6, image 1 of 1
      • Remove the two screws holding part of the floppy processing unit.
      Ask FixBot
    7. Sony Vaio PCG-981L Floppy Drive Replacement: step 7, image 1 of 1
      • Remove the entire floppy drive processing unit.
      Ask FixBot
    8. Sony Vaio PCG-981L Floppy Drive Replacement: step 8, image 1 of 1
      • Here is an isolated image of the core hardware of the floppy drive. This is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to resolder some of the connections.
      Ask FixBot
    9. Sony Vaio PCG-981L Floppy Drive Replacement: step 9, image 1 of 1
      • Here is an isolated image of the floppy drive casing unit.
      Ask FixBot
Loratious
10 Reputation
1 Guide authored
Cal Poly, Team 18-68, Johann Spring 2010 Member of Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 28
All Time: 3,198
