Sony Vaio PCG-981L CMOS Battery Replacement
Views: 6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
39
Past 30 Days:
136
All Time:
6,021
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will help you replace the CMOS or clock battery in your Sony Vaio PCG-981L computer. Before starting, check to make sure your computer model matches the one in this guide as there may be differences in design. Next, make sure all of your files are saved and backed up, shut down your computer properly, and remove all cords.
Tools
    1. Sony Vaio PCG-981L CMOS Battery Replacement, Clock Battery: step 1, image 1 of 1
      • Place the computer on a flat surface.
      Ask FixBot
    2. Sony Vaio PCG-981L CMOS Battery Replacement: step 2, image 1 of 2 Sony Vaio PCG-981L CMOS Battery Replacement: step 2, image 2 of 2
      • Flip your computer upside down.
      • Use a Phillips #1 screwdriver to remove the single screw securing the cover.
      Ask FixBot
    3. Sony Vaio PCG-981L CMOS Battery Replacement: step 3, image 1 of 1
      • Remove the capsule cover to reveal the computer chip.
      Ask FixBot
    4. Sony Vaio PCG-981L CMOS Battery Replacement: step 4, image 1 of 1
      • After removing the cover, identify the two screws holding the computer chip in place.
      • Use a Phillips #1 screwdriver to remove the two screws that secure the computer chip by turning your screwdriver counterclockwise.
      Ask FixBot
    5. Sony Vaio PCG-981L CMOS Battery Replacement: step 5, image 1 of 1
      • Carefully remove the computer chip and set it aside.
      Ask FixBot
    6. Sony Vaio PCG-981L CMOS Battery Replacement: step 6, image 1 of 1
      • Using your thumb or index finger, locate the clock battery on the upper part of the capsule.
      • Apply pressure to the clock battery until it pops out and remove it from your computer.
      Ask FixBot
    7. Sony Vaio PCG-981L CMOS Battery Replacement: step 7, image 1 of 1
      • Push your new clock battery into place using your thumb or index finger at the same place where you removed the old clock battery.
      Ask FixBot
    8. Sony Vaio PCG-981L CMOS Battery Replacement: step 8, image 1 of 1
      • Carefully replace the computer chip and secure the two screws using your Phillips #1 screwdriver by turning the screwdriver clockwise.
      Ask FixBot
    9. Sony Vaio PCG-981L CMOS Battery Replacement: step 9, image 1 of 1
      • Secure the capsule cover with the screw the same way.
      Ask FixBot
    10. Sony Vaio PCG-981L CMOS Battery Replacement: step 10, image 1 of 1
      • Flip your computer right side up and turn it on to make sure everything is functioning properly.
      Ask FixBot
If your computer does not function properly after you have completed this guide, please review the guide to see if you missed a step. If not, contact your computer manufacturer for assistance.
Gabriel Camorlinga
43 Reputation
2 Guides authored
Cal Poly, Team 18-68, Johann Spring 2010 Member of Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 136
All Time: 6,021
