Sony Vaio PCG-981L Battery Replacement
    1. Sony Vaio PCG-981L Battery Replacement, Battery: step 1, image 1 of 1
      • Before starting, be sure the device is turned off and disconnected from any power cords.
      • Place the device on a flat surface.
      Ask FixBot
    2. Sony Vaio PCG-981L Battery Replacement: step 2, image 1 of 1
      • Rotate the device 90° counterclockwise until the battery cover is in front of you.
      • The battery cover is located in the lower right side of the device in this new orientation.
      Ask FixBot
    3. Sony Vaio PCG-981L Battery Replacement: step 3, image 1 of 1
      • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
      • In this new orientation, the battery cover is located on the left side.
      Ask FixBot
    4. Sony Vaio PCG-981L Battery Replacement: step 4, image 1 of 1
      • To remove the battery cover, use your hands to slide it upwards.
      Ask FixBot
    5. Sony Vaio PCG-981L Battery Replacement: step 5, image 1 of 3 Sony Vaio PCG-981L Battery Replacement: step 5, image 2 of 3 Sony Vaio PCG-981L Battery Replacement: step 5, image 3 of 3
      • Once lifted, the battery cover should flip open.
      • Now, carefully remove the battery from the device.
      Ask FixBot
    6. Sony Vaio PCG-981L Battery Replacement: step 6, image 1 of 2 Sony Vaio PCG-981L Battery Replacement: step 6, image 2 of 2
      • Now, the battery should be completely removed from the device.
      • Be sure to dispose of the old battery properly and then you are finished.
      Ask FixBot
Enjoy your new battery. For optimal performance, calibrate your newly installed battery after completing this guide.
Gabriel Camorlinga
43 Reputation
2 Guides authored
Cal Poly, Team 18-68, Johann Spring 2010 Member of Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 111
All Time: 4,500
