Sony Vaio PCG-61411L RAM Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Sony Vaio PCG-61411L RAM Replacement, Battery: step 1, image 1 of 3 Sony Vaio PCG-61411L RAM Replacement, Battery: step 1, image 2 of 3 Sony Vaio PCG-61411L RAM Replacement, Battery: step 1, image 3 of 3
      • Be sure to disconnect the device charger and power down the device before beginning.
      • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
      Ask FixBot
    2. Sony Vaio PCG-61411L RAM Replacement: step 2, image 1 of 3 Sony Vaio PCG-61411L RAM Replacement: step 2, image 2 of 3 Sony Vaio PCG-61411L RAM Replacement: step 2, image 3 of 3
      • Slide the "release" switch to the left and gently lift the battery up to remove it.
      • Completely remove the battery from the device.
      Ask FixBot
    1. Sony Vaio PCG-61411L RAM Replacement, RAM: step 3, image 1 of 1
      • The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
      Ask FixBot
    2. Sony Vaio PCG-61411L RAM Replacement: step 4, image 1 of 2 Sony Vaio PCG-61411L RAM Replacement: step 4, image 2 of 2
      • Unscrew the single PH1 6mm screw at the top of the panel. The screw remains in the panel.
      • Remove the panel by lifting it towards yourself.
      Ask FixBot
    3. Sony Vaio PCG-61411L RAM Replacement: step 5, image 1 of 3 Sony Vaio PCG-61411L RAM Replacement: step 5, image 2 of 3 Sony Vaio PCG-61411L RAM Replacement: step 5, image 3 of 3
      • To remove the individual RAM card panels, snap back the metal latches on each side of the cards.
      Ask FixBot
    4. Sony Vaio PCG-61411L RAM Replacement: step 6, image 1 of 2 Sony Vaio PCG-61411L RAM Replacement: step 6, image 2 of 2
      • After pinching the metal latches, the RAM card should pop out slightly upward.
      • Remove the cards by pulling them out to the left.
      • Repeat for the second panel of RAM cards.
      Ask FixBot
Sean Lyon
381 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 28
All Time: 1,498
