Sony Vaio PCG-61411L Optical Disc Drive Replacement
    1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: step 1, image 1 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: step 1, image 2 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: step 1, image 3 of 3
      • Be sure to disconnect the device charger and power down the device before beginning.
      • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
      Ask FixBot
    2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 2, image 1 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 2, image 2 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 2, image 3 of 3
      • Slide the "release" switch to the left and gently lift the battery up to remove it.
      • Completely remove the battery from the device.
      Ask FixBot
    1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Hard Drive: step 3, image 1 of 1
      • The hard drive panel is located in the bottom right corner of the device.
      Ask FixBot
    2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 4, image 1 of 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 4, image 2 of 2
      • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
      • Remove the panel by pulling it up towards yourself.
      Ask FixBot
    3. Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 5, image 1 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 5, image 2 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 5, image 3 of 3
      • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
      • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
      • Carefully remove the silver hard drive cover.
      Ask FixBot
    4. Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 6, image 1 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 6, image 2 of 3 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 6, image 3 of 3
      • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
      Ask FixBot
    1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: step 7, image 1 of 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: step 7, image 2 of 2
      • Remove the 5mm screws with the PH0 screwdriver.
      • Remove the 3mm screws with the PH0 screwdriver.
      Ask FixBot
    2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 8, image 1 of 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 8, image 2 of 2
      • Lift the backplate from bottom right and left corner and remove it from the laptop.
      Ask FixBot
    3. Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 9, image 1 of 2 Sony Vaio PCG-61411L Optical Disc Drive Replacement: step 9, image 2 of 2
      • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
      Ask FixBot
Patrick Jean Baptiste
214 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 43
All Time: 1,069
