Sony Vaio PCG-4G1L Optical Drive Replacement
    1. Sony Vaio PCG-4G1L Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer and disconnect the charging cable.
      • Failing to unplug the cable can result in electric shock.
      Ask FixBot
    2. Sony Vaio PCG-4G1L Optical Drive Replacement: step 2, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 2, image 2 of 2
      • Slide battery release toggle switch towards the "RELEASE" print.
      Ask FixBot
    3. Sony Vaio PCG-4G1L Optical Drive Replacement: step 3, image 1 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 3, image 2 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 3, image 3 of 3
      • Apply pressure with your thumb on the grip.
      • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
      Ask FixBot
    1. Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: step 4, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: step 4, image 2 of 2
      • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
      Ask FixBot
    2. Sony Vaio PCG-4G1L Optical Drive Replacement: step 5, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 5, image 2 of 2
      • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
      • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
      Ask FixBot
    3. Sony Vaio PCG-4G1L Optical Drive Replacement: step 6, image 1 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 6, image 2 of 3 Sony Vaio PCG-4G1L Optical Drive Replacement: step 6, image 3 of 3
      • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
      • Use the plastic opening tool to release the clamp.
      • Using slight pressure, remove the ribbon cable with your fingers.
      Ask FixBot
    1. Sony Vaio PCG-4G1L Optical Drive Replacement, Network Antenna: step 7, image 1 of 1
      • Swivel the Network Antenna up so that it points upward.
      Ask FixBot
    2. Sony Vaio PCG-4G1L Optical Drive Replacement: step 8, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 8, image 2 of 2
      • Pinch thumb and index finger at the Network Antenna's base.
      • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
      • Pull the Network Antenna off.
      Ask FixBot
    1. Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: step 9, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: step 9, image 2 of 2
      • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
      Ask FixBot
    2. Sony Vaio PCG-4G1L Optical Drive Replacement: step 10, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 10, image 2 of 2
      • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
      Ask FixBot
    3. Sony Vaio PCG-4G1L Optical Drive Replacement: step 11, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the cable by using the precision tweezers.
      • Slowly pry out the ribbon cable by using the plastic opening tool.
      Ask FixBot
    4. Sony Vaio PCG-4G1L Optical Drive Replacement: step 12, image 1 of 1
      • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
      • Remove the plastic cover by inserting the plastic opening tool around the edge.
      Ask FixBot
    5. Sony Vaio PCG-4G1L Optical Drive Replacement: step 13, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 13, image 2 of 2
      • Disconnect the ribbon cable by pulling straight up with your fingers.
      Ask FixBot
    1. Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: step 14, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: step 14, image 2 of 2
      • Insert the PH0.8 bit into the pin hole to eject the optical drive.
      Ask FixBot
    2. Sony Vaio PCG-4G1L Optical Drive Replacement: step 15, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 15, image 2 of 2
      • Remove one 4mm Phillips #0 pan head screw, using a Bit Driver with a Phillips PH000 bit.
      • Remove three 5mm Phillips #0 flat head screws, using a Bit Driver with a Phillips PH000 bit.
      Ask FixBot
    3. Sony Vaio PCG-4G1L Optical Drive Replacement: step 16, image 1 of 2 Sony Vaio PCG-4G1L Optical Drive Replacement: step 16, image 2 of 2
      • Apply pressure to the ribbon cable, then pick up and pull the optical drive away from the cable.
      Ask FixBot
Cole Collins
211 Reputation
4 Guides authored
USF Tampa, Team 2-3, Cagle Fall 2016 Member of USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 100
All Time: 1,260
