Sony Vaio PCG-4G1L Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
92
All Time:
1,589
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Common reasons for removing the battery could be a device shutting down while unplugged, or a battery that does not charge.
In this guide, you will learn how to replace the battery for your device. Please remember to unplug the charging cable, since it could result in electric shock.
    1. Sony Vaio PCG-4G1L Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer and disconnect the charging cable.
      • Failing to unplug the cable can result in electric shock.
      Ask FixBot
    2. Sony Vaio PCG-4G1L Battery Replacement: step 2, image 1 of 2 Sony Vaio PCG-4G1L Battery Replacement: step 2, image 2 of 2
      • Slide battery release toggle switch towards the "RELEASE" print.
      Ask FixBot
    3. Sony Vaio PCG-4G1L Battery Replacement: step 3, image 1 of 3 Sony Vaio PCG-4G1L Battery Replacement: step 3, image 2 of 3 Sony Vaio PCG-4G1L Battery Replacement: step 3, image 3 of 3
      • Apply pressure with your thumb on the grip.
      • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
      Ask FixBot
Cole Collins
211 Reputation
4 Guides authored
USF Tampa, Team 2-3, Cagle Fall 2016 Member of USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 92
All Time: 1,589
