Sony Vaio PCG-4121GL Keyboard Replacement
    1. Sony Vaio PCG-4121GL Keyboard Replacement, Battery: step 1, image 1 of 2 Sony Vaio PCG-4121GL Keyboard Replacement, Battery: step 1, image 2 of 2
      • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
      Ask FixBot
    2. Sony Vaio PCG-4121GL Keyboard Replacement: step 2, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 2, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 2, image 3 of 3
      • Pull the bottom plate towards yourself until it unhinges fully.
      • Once the plate is free from the backing remove it completely.
      Ask FixBot
    3. Sony Vaio PCG-4121GL Keyboard Replacement: step 3, image 1 of 1
      • Look for the blue tab that is located to the bottom left of the battery.
      Ask FixBot
    4. Sony Vaio PCG-4121GL Keyboard Replacement: step 4, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 4, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 4, image 3 of 3
      • Pull the blue tab towards yourself until you hear a click.
      • Once the blue tab is released, pull up on the battery.
      • Once the battery can move freely, take it out completely.
      • It may be helpful to have a spudger to make it easier to release the blue tab.
      Ask FixBot
    1. Sony Vaio PCG-4121GL Keyboard Replacement, Keyboard: step 5, image 1 of 2 Sony Vaio PCG-4121GL Keyboard Replacement, Keyboard: step 5, image 2 of 2
      • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
      • Remove eight 5mm Phillips #0 screws.
      Ask FixBot
    2. Sony Vaio PCG-4121GL Keyboard Replacement: step 6, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 6, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 6, image 3 of 3
      • Carefully remove the disk drive from its compartment.
      Ask FixBot
    3. Sony Vaio PCG-4121GL Keyboard Replacement: step 7, image 1 of 2 Sony Vaio PCG-4121GL Keyboard Replacement: step 7, image 2 of 2
      • Remove the three 2mm Phillips #00 screws located on the top right edge.
      Ask FixBot
    4. Sony Vaio PCG-4121GL Keyboard Replacement: step 8, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 8, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 8, image 3 of 3
      • Gently pull apart the top and bottom plastic bodies.
      • Carefully lift up tabs to detach cable connectors.
      • Slowly detach bottom component to avoid tearing wires/connectors.
      Ask FixBot
    5. Sony Vaio PCG-4121GL Keyboard Replacement: step 9, image 1 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 9, image 2 of 3 Sony Vaio PCG-4121GL Keyboard Replacement: step 9, image 3 of 3
      • Remove the tape strips along the edge of the keyboard.
      • Once the keyboard is disconnected, slowly poke out keys one-by-one.
      • When the keyboard is free to move, remove it completely.
      • The keyboard is held in place with glue, once it is removed it is likely that it will not go back in the same way.
      Ask FixBot
4 other people completed this guide.
Miguel Camarena
397 Reputation
3 Guides authored
Cal Poly, Team S2-G2, White Winter 2019 Member of Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Members
60 Guides authored
1 Guide Comment
Im having trouble putting the keyboard cables back
Ishaan Patel - Reply Share
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 78
All Time: 2,530
