Sony Vaio PCG-4121GL Battery Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
102
All Time:
3,931
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your laptop is not powering on or is not holding a charge, a faulty battery could be the issue. Before starting this guide, it may be helpful to have a secure place to put the screws after they have been removed.
Tools
    1. Sony Vaio PCG-4121GL Battery Replacement, Battery: step 1, image 1 of 2 Sony Vaio PCG-4121GL Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
      Ask FixBot
    2. Sony Vaio PCG-4121GL Battery Replacement: step 2, image 1 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 2, image 2 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 2, image 3 of 3
      • Pull the bottom plate towards yourself until it unhinges fully.
      • Once the plate is free from the backing remove it completely.
      Ask FixBot
    3. Sony Vaio PCG-4121GL Battery Replacement: step 3, image 1 of 1
      • Look for the blue tab that is located to the bottom left of the battery.
      Ask FixBot
    4. Sony Vaio PCG-4121GL Battery Replacement: step 4, image 1 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 4, image 2 of 3 Sony Vaio PCG-4121GL Battery Replacement: step 4, image 3 of 3
      • Pull the blue tab towards yourself until you hear a click.
      • Once the blue tab is released, pull up on the battery.
      • Once the battery can move freely, take it out completely.
      • It may be helpful to have a spudger to make it easier to release the blue tab.
      Ask FixBot
McKinley Hubred
127 Reputation
1 Guide authored
Cal Poly, Team S2-G2, White Winter 2019 Member of Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 102
All Time: 3,931
