Sony Vaio PCG-31311L RAM Replacement
    1. Sony Vaio PCG-31311L RAM Replacement, RAM: step 1, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement, RAM: step 1, image 2 of 2
      • Start with device closed, powered off, and upside down.
      • Locate 3 screws on the bottom plate and unscrew.
      • These screws do not detach from the plate.
      Ask FixBot
    2. Sony Vaio PCG-31311L RAM Replacement: step 2, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry up on the bottom plate.
      • Lift up and away from the device.
      Ask FixBot
    3. Sony Vaio PCG-31311L RAM Replacement: step 3, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement: step 3, image 2 of 2
      • Locate the 2 clips on either side of the RAM chip.
      • Push both of them out and away from the RAM chip. The RAM chip should pop up.
      • Slowly remove the chip from the device
      • Make note of which side the slot is on in order to correctly reinstall the RAM chip.
      Ask FixBot
    4. Sony Vaio PCG-31311L RAM Replacement: step 4, image 1 of 2 Sony Vaio PCG-31311L RAM Replacement: step 4, image 2 of 2
      • Repeat Step 3 on the other RAM chip
      Ask FixBot
Tyler
69 Reputation
5 Guides authored
USF Tampa, Team 1-1, Lacy Fall 2016 Member of USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 97
All Time: 1,520
