Sony Vaio PCG-31311L Motherboard Replacement
    1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: step 1, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: step 1, image 2 of 2
      • Start with device closed, powered off, and upside down.
      • Locate 3 screws on the bottom plate and unscrew
      • These screws do not detach from the bottom plate.
      Ask FixBot
    2. Sony Vaio PCG-31311L Motherboard Replacement: step 2, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry up on the plate and remove from device.
      Ask FixBot
    3. Sony Vaio PCG-31311L Motherboard Replacement: step 3, image 1 of 1
      • Locate screw labeled "KB" and remove.
      Ask FixBot
    4. Sony Vaio PCG-31311L Motherboard Replacement: step 4, image 1 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 4, image 2 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 4, image 3 of 3
      • Use a plastic opening tool tool to pry around the edge of the keyboard.
      Ask FixBot
    5. Sony Vaio PCG-31311L Motherboard Replacement: step 5, image 1 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 5, image 2 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 5, image 3 of 3
      • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
      • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
      • Once the ribbon cable has been detached, lift the keyboard away from the device.
      Ask FixBot
    1. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: step 6, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
      • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
      Ask FixBot
    2. Sony Vaio PCG-31311L Motherboard Replacement: step 7, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement: step 7, image 2 of 2
      • Locate the LCD ribbon cable
      • Pull up and away from device to detach the LCD ribbon cable.
      Ask FixBot
    3. Sony Vaio PCG-31311L Motherboard Replacement: step 8, image 1 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 8, image 2 of 3 Sony Vaio PCG-31311L Motherboard Replacement: step 8, image 3 of 3
      • Close and flip over laptop.
      • Locate the WiFi network card.
      • Use the plastic opening tool to pry up the two connectors.
      Ask FixBot
    4. Sony Vaio PCG-31311L Motherboard Replacement: step 9, image 1 of 2 Sony Vaio PCG-31311L Motherboard Replacement: step 9, image 2 of 2
      • Locate the 6 screws on the bottom and remove.
      • Remove the final screw in the center to release the motherboard from the case.
      Ask FixBot
Tyler
69 Reputation
5 Guides authored
USF Tampa, Team 1-1, Lacy Fall 2016 Member of USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 2,199
