Sony Vaio Fit SVF14A190X Battery Replacement
    1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: step 1, image 1 of 1
      • Make sure the battery is drained or the computer is turned off.
      • Use the Phillips head screw driver to remove the eleven 6 mm screws.
      • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
      Ask FixBot
    2. Sony Vaio Fit SVF14A190X  Battery Replacement: step 2, image 1 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 2, image 2 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 2, image 3 of 3
      • Insert the plastic opening tool into the slit of the CD drive.
      • Then pull it outwards.
      • Grab the CD drive with your hand.
      • Take the CD drive all the way out.
      Ask FixBot
    3. Sony Vaio Fit SVF14A190X  Battery Replacement: step 3, image 1 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 3, image 2 of 3 Sony Vaio Fit SVF14A190X  Battery Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
      • Move the plastic opening tool around all sides of the device.
      • Peel off the back cover.
      Ask FixBot
    4. Sony Vaio Fit SVF14A190X  Battery Replacement: step 4, image 1 of 2 Sony Vaio Fit SVF14A190X  Battery Replacement: step 4, image 2 of 2
      • Use the Phillips head screw driver to remove the four 7 mm screws.
      • Lift the battery out with your hand.
      Ask FixBot
Randal Crosby
187 Reputation
1 Guide authored
USF Tampa, Team S11-G3, Cheng Spring 2018 Member of USF Tampa, Team S11-G3, Cheng Spring 2018
USFT-CHENG-S18S11G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 60
All Time: 2,625
