Sony Vaio Fit SVF13N1ASNS Display Replacement
    1. Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: step 1, image 1 of 2 Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: step 1, image 2 of 2
      • Remove the following ten screws from the bottom case of the laptop:
      • Two 6.5mm Phillips #00 Phillips screws.
      • Four 8.95mm Phillips #00 screws.
      • Four 6.25mm Phillips #00 screws.
      • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
      Ask FixBot
    2. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 2, image 1 of 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to separate the bottom cover from the laptop.
      • Lift the lower cover and pull away from the laptop.
      Ask FixBot
    3. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 3, image 1 of 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 3, image 2 of 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 3, image 3 of 3
      • Remove the eight Phillips #00 screws from the battery:
      • Six 4.65mm screws.
      • Two 4.65mm screws.
      Ask FixBot
    4. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 4, image 1 of 1
      • Lift the battery up and pull it out of the laptop.
      Ask FixBot
    1. Sony Vaio Fit SVF13N1ASNS Display Replacement, Display: step 5, image 1 of 1
      • Open the laptop and rotate the screen to the back side.
      • Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
      Ask FixBot
    2. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 6, image 1 of 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 6, image 2 of 2
      • Rotate the screen back and close the laptop.
      • Use a plastic opening tool to carefully pry up the back plastic case.
      • Remove the back plastic case by sliding it down and pulling upwards.
      Ask FixBot
    3. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 7, image 1 of 2 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 7, image 2 of 2
      • Remove the thirteen 2.85mm Phillips #00 screws from the screen.
      Ask FixBot
    4. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 8, image 1 of 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 8, image 2 of 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 8, image 3 of 3
      • Use a spudger to lift up the black latch on the ZIF connector.
      • Pull the display ribbon cable out of the ZIF connector.
      Ask FixBot
    5. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 9, image 1 of 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 9, image 2 of 3 Sony Vaio Fit SVF13N1ASNS Display Replacement: step 9, image 3 of 3
      • Remove the display cable peeling up the tape.
      • The display cable locking mechanism is attached to the tape.
      Ask FixBot
    6. Sony Vaio Fit SVF13N1ASNS Display Replacement: step 10, image 1 of 1
      • Remove the display.
      Ask FixBot
3 other people completed this guide.
Althea McDavid
857 Reputation
6 Guides authored
USF Tampa, Team S2-G4, Nance Spring 2018 Member of USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Members
70 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 40
All Time: 3,093
