Sony Vaio Duo 11 SSD Replacement
Views: 44K
View statistics:
Past 24 Hours:
5
Past 7 Days:
46
Past 30 Days:
208
All Time:
43,606
Comments: 16
2 comments on steps, 14 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 hours
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Before start the procedure, make a system backup (I use ToDo Backup Free).
Some pictures were found in:
http://henjinkutsu.com/text/pc/svd1121aj...
http://blogs.yahoo.co.jp/haitora_neko/30...
http://forum.tabletpcreview.com/sony/553...
Tools
    1. Sony Vaio Duo 11 SSD Replacement, SSD: step 1, image 1 of 1
      • Make a system backup!
      Ask FixBot
    2. Sony Vaio Duo 11 SSD Replacement: step 2, image 1 of 2 Sony Vaio Duo 11 SSD Replacement: step 2, image 2 of 2
      • Using a spudger, remove the rubber screw covers.
      • Gently remove the speaker covers.
      Ask FixBot
    3. Sony Vaio Duo 11 SSD Replacement: step 3, image 1 of 1
      • Use a sharp tool to lift up the laptop's cover
      Ask FixBot
    4. Sony Vaio Duo 11 SSD Replacement: step 4, image 1 of 1
      • Remove cover
      Ask FixBot
    5. Sony Vaio Duo 11 SSD Replacement: step 5, image 1 of 1
      • Remove all the screws. (Attention: these screws are different! Save them.)
      Ask FixBot
    6. Sony Vaio Duo 11 SSD Replacement: step 6, image 1 of 2 Sony Vaio Duo 11 SSD Replacement: step 6, image 2 of 2
      • Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
      • Remove the screws (circled in red) and remove the battery.
      • When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
      Ask FixBot
    7. Sony Vaio Duo 11 SSD Replacement: step 7, image 1 of 1
      • Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
      Ask FixBot
    8. Sony Vaio Duo 11 SSD Replacement: step 8, image 1 of 1
      • Remove these screws to make it easier to remove the SSD.
      Ask FixBot
    9. Sony Vaio Duo 11 SSD Replacement: step 9, image 1 of 1
      • The remove of the ssd
      • Remove the SSD (gently)
      • Replace the SSD ( it is a mSATA SSD )
      • Put back the screws and close the unit
      Ask FixBot
26 other people completed this guide.
Zero
880 Reputation
1 Guide authored
14 Guide Comments
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
Anwar - Reply Share
1TB ssd here I come!!!!
jamice4u - Reply Share
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
scorpiotide - Reply Share
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps - Reply Share
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Nathan Price - Reply Share
Past 24 Hours: 5
Past 7 Days: 46
Past 30 Days: 208
All Time: 43,606
