Sony VAIO VPCF 132FX Bottom Case Replacement
    1. Sony VAIO VPCF 132FX Bottom Case Replacement, Battery: step 1, image 1 of 1
      • Remove all wires then flip the laptop
      Ask FixBot
    2. Sony VAIO VPCF 132FX Bottom Case Replacement: step 2, image 1 of 2 Sony VAIO VPCF 132FX Bottom Case Replacement: step 2, image 2 of 2
      • Remove the battery
      Ask FixBot
    1. Sony VAIO VPCF 132FX Bottom Case Replacement, RAM: step 3, image 1 of 3 Sony VAIO VPCF 132FX Bottom Case Replacement, RAM: step 3, image 2 of 3 Sony VAIO VPCF 132FX Bottom Case Replacement, RAM: step 3, image 3 of 3
      • Flip the Laptop, and unscrew the RAM cover.
      Ask FixBot
    2. Sony VAIO VPCF 132FX Bottom Case Replacement: step 4, image 1 of 2 Sony VAIO VPCF 132FX Bottom Case Replacement: step 4, image 2 of 2
      • Unlock the RAM by pulling the locks outward.
      • You'll know if its unlocked if it flips up in 45 degrees.
      Ask FixBot
    3. Sony VAIO VPCF 132FX Bottom Case Replacement: step 5, image 1 of 2 Sony VAIO VPCF 132FX Bottom Case Replacement: step 5, image 2 of 2
      • Pull the outer RAM. Repeat Step 4 and 5 for the other RAM.
      • When returning, put the RAM back in at 45 degree angle, NOT 90 degree angle.
      Ask FixBot
    1. Sony VAIO VPCF 132FX Bottom Case Replacement, CD/DVD Drive: step 6, image 1 of 2 Sony VAIO VPCF 132FX Bottom Case Replacement, CD/DVD Drive: step 6, image 2 of 2
      • Remove the 2 screws holding the CD/DVD Drive.
      Ask FixBot
    2. Sony VAIO VPCF 132FX Bottom Case Replacement: step 7, image 1 of 2 Sony VAIO VPCF 132FX Bottom Case Replacement: step 7, image 2 of 2
      • Slide the CD/DVD Drive out.
      Ask FixBot
    1. Sony VAIO VPCF 132FX Bottom Case Replacement, Hard Disk Drive / Solid State Drive: step 8, image 1 of 3 Sony VAIO VPCF 132FX Bottom Case Replacement, Hard Disk Drive / Solid State Drive: step 8, image 2 of 3 Sony VAIO VPCF 132FX Bottom Case Replacement, Hard Disk Drive / Solid State Drive: step 8, image 3 of 3
      • Remove the screws.
      • Slide the HD cover outward then lift.
      Ask FixBot
    2. Sony VAIO VPCF 132FX Bottom Case Replacement: step 9, image 1 of 3 Sony VAIO VPCF 132FX Bottom Case Replacement: step 9, image 2 of 3 Sony VAIO VPCF 132FX Bottom Case Replacement: step 9, image 3 of 3
      • Slide to where the arrow points to unlock the HD.
      • Hold it at the side. Never touch the circuits.
      Ask FixBot
    3. Sony VAIO VPCF 132FX Bottom Case Replacement: step 10, image 1 of 1
      • Remove the 4 screws at the side and remove the HDD/SSD
      Ask FixBot
    1. Sony VAIO VPCF 132FX Bottom Case Replacement, Bottom Case: step 11, image 1 of 2 Sony VAIO VPCF 132FX Bottom Case Replacement, Bottom Case: step 11, image 2 of 2
      • Remove all the other screws.
      • Dont forget the 3 screws after you remove the CD/DVD Drive.
      Ask FixBot
Marjorie
2,493 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 94
All Time: 1,190
