Sony VAIO VPCEE26FX Optical Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
65
All Time:
946
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide shows how to remove/replace the CD-ROM/optical drive on the Sony VAIO VPCEE26FX laptop computer.
    1. Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPCEE26FX Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Ensure that the laptop is powered off before disconnecting the battery.
      • Flip the laptop over so the underside of the laptop is facing up.
      Ask FixBot
    2. Sony VAIO VPCEE26FX Optical Drive Replacement: step 2, image 1 of 2 Sony VAIO VPCEE26FX Optical Drive Replacement: step 2, image 2 of 2
      • Slide the two tabs towards each other until the battery disconnects slightly from its position.
      • Carefully lift the battery out of its position away from the laptop.
      • The battery is not pictured here, since it is missing from this particular device.
      Ask FixBot
    1. Sony VAIO VPCEE26FX Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
      • Use a JIS #0 screwdriver to remove the 4mm screw from its place.
      Ask FixBot
    2. Sony VAIO VPCEE26FX Optical Drive Replacement: step 4, image 1 of 2 Sony VAIO VPCEE26FX Optical Drive Replacement: step 4, image 2 of 2
      • Remove the optical drive gently away from its holder on the laptop.
      Ask FixBot
Christopher Hover
679 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 65
All Time: 946
