Sony VAIO VPCEE26FX Hard Disk Drive Replacement
    1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: step 1, image 2 of 2
      • Ensure that the laptop is powered off before disconnecting the battery.
      • Flip the laptop over so the underside of the laptop is facing up.
      Ask FixBot
    2. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: step 2, image 1 of 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement: step 2, image 2 of 2
      • Slide the two tabs towards each other until the battery disconnects slightly from its position.
      • Carefully lift the battery out of its position away from the laptop.
      • The battery is not pictured here, since it is missing from this particular device.
      Ask FixBot
    1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: step 3, image 1 of 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: step 3, image 2 of 2
      • Using a JIS #0 screwdriver, remove the two 4mm screws securing the hard drive cover to the laptop.
      • Lift the hard drive up and out of its place.
      • The drive cover and hard drive are not pictured. They are both missing from this particular device.
      Ask FixBot
Christopher Hover
679 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 24
All Time: 2,303
