Sony VAIO VPCEC1M1E Keyboard Replacement
    1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Remove the following color-coded screws:
      • These screws secure the RAM and hard drive covers, respectively.
      • These screws secure the optical drive to the lower case of the laptop.
      • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
      Ask FixBot
    2. Sony VAIO VPCEC1M1E Keyboard Replacement: step 2, image 1 of 1
      • Remove the following screws:
      • Five screws highlighted in orange.
      • Two screws highlighted in blue.
      • Pry the hard drive connector upwards from its socket on the logic board.
      Ask FixBot
    3. Sony VAIO VPCEC1M1E Keyboard Replacement: step 3, image 1 of 1
      • Release the highlighted clips to remove the upper case of the keyboard.
      Ask FixBot
    4. Sony VAIO VPCEC1M1E Keyboard Replacement: step 4, image 1 of 3 Sony VAIO VPCEC1M1E Keyboard Replacement: step 4, image 2 of 3 Sony VAIO VPCEC1M1E Keyboard Replacement: step 4, image 3 of 3
      • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap and not the socket itself.
      • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
      Ask FixBot
Finish Line
8 other people completed this guide.
Stephan
217 Reputation
1 Guide authored
3 Guide Comments
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - Reply Share
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - Reply Share
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 115
All Time: 24,488
