Sony VAIO VPC-EB33FM Hard Drive Replacement
Views: 19K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
109
All Time:
19,293
Comments: 1
1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide will show you how to replace the hard drive in a Sony VAIO VPC-EB33FM laptop.
There are several signs of a failing hard drive including sluggish response, freezing, overheating, and even audible clicking or whirring noises from your computer. Hard drives store data, operating systems, and your applications, so you will want to replace that hard drive before it is completely worn out. An earlier replacement will ensure more, if not all, your data is saved.
However, before you uninstall your failing hard drive, you will want to make sure you have backed up any data you would like to save. This includes (but is not limited to), documents, files, music, and photos. Also, have your new hard drive readily available to make this transition as smooth as possible. When you have covered these initial steps, you are ready to begin!
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: step 1, image 1 of 2 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Power down the laptop by pressing the power button.
      • Turn the laptop onto its backside.
      Ask FixBot
    2. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 2, image 1 of 1
      • To release the battery, hold both the release button and the unlock button at the same time.
      Ask FixBot
    3. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 3, image 1 of 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: step 3, image 2 of 2
      • Remove the battery out from the notch while continuing to hold the release button.
      Ask FixBot
    1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
      Ask FixBot
    2. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 5, image 1 of 3 Sony VAIO VPC-EB33FM Hard Drive Replacement: step 5, image 2 of 3 Sony VAIO VPC-EB33FM Hard Drive Replacement: step 5, image 3 of 3
      • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
      • You may need to use your other hand to safely remove the panel.
      • You can also use a spudger for this step.
      Ask FixBot
    3. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 6, image 1 of 1
      • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    4. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 7, image 1 of 1
      • Grab the tab between your thumb and index finger.
      • Hold the hard drive securely in a horizontal position using your other hand.
      • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
      • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
      Ask FixBot
    5. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 8, image 1 of 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: step 8, image 2 of 2
      • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
      • Pull the hard drive out.
      Ask FixBot
    6. Sony VAIO VPC-EB33FM Hard Drive Replacement: step 9, image 1 of 2 Sony VAIO VPC-EB33FM Hard Drive Replacement: step 9, image 2 of 2
      • If you need to remove the bracket from the hard drive, follow the next few steps:
      • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
      • Lift the bracket off the hard drive.
      Ask FixBot
9 other people completed this guide.
Christian
195 Reputation
1 Guide authored
Cal Poly, Team 18-39, Regan Winter 2013 Member of Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Members
72 Guides authored
1 Guide Comment
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 109
All Time: 19,293
