Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓This guide will inform readers on how to safely uninstall the display of the Sony VAIO VPC-EB33FM laptop.
Power down the laptop by pressing the power button.
Turn the laptop onto its backside.
Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
Using a Phillips #00 screwdriver remove the following screws securing the back cover :
Two 3.8-mm screws
Two 8.9-mm screws
Twelve 7.75-mm screws
Use a Phillips #1 screwdriver to remove the three 8.88-mm screws attached to the metal hinge at the corner of the laptop.
Repeat for the three screws on the opposite corner.
Use the plastic opening tool to separate the plastic front cover by wedging the tool along the seam.
Flip the laptop to the other side. If the front cover is still attached continue using the plastic opening tool to separate.
Carefully lift up the display. Completely detach the front plastic cover.
2 other people completed this guide.
