Sony VAIO VGN-FW 590 Keyboard Replacement
    1. Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: step 1, image 1 of 2 Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
      • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
      • Locate the battery pack between the two "screen swivels" at the top of the computer back.
      Ask FixBot
    2. Sony VAIO VGN-FW 590 Keyboard Replacement: step 2, image 1 of 2 Sony VAIO VGN-FW 590 Keyboard Replacement: step 2, image 2 of 2
      • Locate two sliding release switches below the battery pack.
      • Slide the "Lock" release to the right toward the center of the computer.
      • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
      Ask FixBot
    3. Sony VAIO VGN-FW 590 Keyboard Replacement: step 3, image 1 of 2 Sony VAIO VGN-FW 590 Keyboard Replacement: step 3, image 2 of 2
      • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
      • Once the battery pack has popped out of its compartment, lift it out of the computer.
      Ask FixBot
    1. Sony VAIO VGN-FW 590 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Remove the circled screws using the Phillips #0 screwdriver.
      • The outer two screws are 7.7mm
      • The center two screws are 2.5mm
      • The bottom screw is 7.6mm
      Ask FixBot
    2. Sony VAIO VGN-FW 590 Keyboard Replacement: step 5, image 1 of 1
      • Open the computer
      Ask FixBot
    3. Sony VAIO VGN-FW 590 Keyboard Replacement: step 6, image 1 of 1
      • Remove the audio panel above the keyboard.
      • Lift one corner gently with a flat tool or fingernail.
      • Pull the rest of the panel gently out by hand.
      Ask FixBot
    4. Sony VAIO VGN-FW 590 Keyboard Replacement: step 7, image 1 of 1
      • Lift the keyboard gently, starting with one of the top corners.
      • Pull keyboard gently from body of computer to prevent warping or breakage.
      • Caution Do not remove completely.
      Ask FixBot
    5. Sony VAIO VGN-FW 590 Keyboard Replacement: step 8, image 1 of 3 Sony VAIO VGN-FW 590 Keyboard Replacement: step 8, image 2 of 3 Sony VAIO VGN-FW 590 Keyboard Replacement: step 8, image 3 of 3
      • Locate the connector ribbon behind the keyboard.
      • Gently pull the ribbon from the locking device. It may take a few tries.
      • Caution Do not tear the ribbon.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,458
