Up to 20% off select tools
Sony VAIO PCG-F360 Single Key Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
84
All Time:
800
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Spudger
    4.9
    1. Sony VAIO PCG-F360 Single Key Replacement, Battery: step 1, image 1 of 1
      • Position the laptop screen-side down as shown.
      • In this position the battery housing will be located on the right hand side.
      Ask FixBot
    2. Sony VAIO PCG-F360 Single Key Replacement: step 2, image 1 of 1
      • Lift the panel up and then out to gain access to the battery.
      Ask FixBot
    3. Sony VAIO PCG-F360 Single Key Replacement: step 3, image 1 of 1
      • Use the indentations to pull the old battery out.
      Ask FixBot
    4. Sony VAIO PCG-F360 Single Key Replacement: step 4, image 1 of 1
      • The battery is now removed and it is safe to move on to uninstalling other components.
      Ask FixBot
    1. Sony VAIO PCG-F360 Single Key Replacement, Single Key: step 5, image 1 of 3 Sony VAIO PCG-F360 Single Key Replacement, Single Key: step 5, image 2 of 3 Sony VAIO PCG-F360 Single Key Replacement, Single Key: step 5, image 3 of 3
      • Use the pludger to pop off the key by prying under it.
      • You now can clean and replace the key.
      Ask FixBot
Author
with
Hannah Millea
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 84
All Time: 800
