Sony VAIO PCG-933A Hard Drive Replacement
Views: 8.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
124
All Time:
8,682
Comments: 3
3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This repair guide shows how to replace your hard drive.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Sony VAIO PCG-933A Hard Drive Replacement, Battery: step 1, image 1 of 2 Sony VAIO PCG-933A Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Turn the laptop upside down so that the top is sitting on a flat surface.
      • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
      Ask FixBot
    2. Sony VAIO PCG-933A Hard Drive Replacement: step 2, image 1 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 2, image 2 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 2, image 3 of 3
      • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
      • You should now be able to pull the battery out.
      Ask FixBot
    1. Sony VAIO PCG-933A Hard Drive Replacement, Keyboard: step 3, image 1 of 1
      • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Sony VAIO PCG-933A Hard Drive Replacement: step 4, image 1 of 2 Sony VAIO PCG-933A Hard Drive Replacement: step 4, image 2 of 2
      • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
      • This will release the speaker grille.
      Ask FixBot
    3. Sony VAIO PCG-933A Hard Drive Replacement: step 5, image 1 of 1
      • Flip the computer so the key board is facing up.
      Ask FixBot
    4. Sony VAIO PCG-933A Hard Drive Replacement: step 6, image 1 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 6, image 2 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 6, image 3 of 3
      • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
      • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
      Ask FixBot
    5. Sony VAIO PCG-933A Hard Drive Replacement: step 7, image 1 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 7, image 2 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 7, image 3 of 3
      • Remove the 4mm screw in the center using a Phillips screwdriver.
      • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
      • The keyboard can now be removed.
      Ask FixBot
    1. Sony VAIO PCG-933A Hard Drive Replacement, Hard Drive: step 8, image 1 of 2 Sony VAIO PCG-933A Hard Drive Replacement, Hard Drive: step 8, image 2 of 2
      • Remove the two 4mm Phillips screws in the center of the computer located on each side of the copper electrical strip.
      Ask FixBot
    2. Sony VAIO PCG-933A Hard Drive Replacement: step 9, image 1 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 9, image 2 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 9, image 3 of 3
      • Remove the four 4mm Phillips screws around the hard drive cage.
      • WARNING: DVD drive is now loose as well.
      • Carefully lift the hard drive cage out.
      • Carefully disconnect the copper strip to pull out the hard drive.
      Ask FixBot
    3. Sony VAIO PCG-933A Hard Drive Replacement: step 10, image 1 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 10, image 2 of 3 Sony VAIO PCG-933A Hard Drive Replacement: step 10, image 3 of 3
      • Remove the four 4mm Phillips screws that hold the hard drive in the hard drive cage.
      • Gently remove the hard drive from the cage.
      • Gently remove the copper electrical strip from the harddrive.
      Ask FixBot
4 other people completed this guide.
Sara Lillard
165 Reputation
8 Guides authored
Cal Poly, Team 12-36, Maness Spring 2011 Member of Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Members
96 Guides authored
3 Guide Comments
Totally dident expect to find a guide for taking this one apart. Appreciate it!
pat - Reply Share
Complete Life Saver Thank you Very much for taking the time to Make an Easily Fallowed guide for this laptop. very very much Appreciated
colbailey1 - Reply Share
would recommend getting a #00 bit for this repair just as well, some of those old screws can be a pain, if the laptop was previously opened or has wrong screws in place
Mr Arch Linux - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 124
All Time: 8,682
