Sony VAIO PCG-933A Fan Replacement
    1. Sony VAIO PCG-933A Fan Replacement, Battery: step 1, image 1 of 2 Sony VAIO PCG-933A Fan Replacement, Battery: step 1, image 2 of 2
      • Turn the laptop upside down so that the top is sitting on a flat surface.
      • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
      Ask FixBot
    2. Sony VAIO PCG-933A Fan Replacement: step 2, image 1 of 3 Sony VAIO PCG-933A Fan Replacement: step 2, image 2 of 3 Sony VAIO PCG-933A Fan Replacement: step 2, image 3 of 3
      • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
      • You should now be able to pull the battery out.
      Ask FixBot
    1. Sony VAIO PCG-933A Fan Replacement, Keyboard: step 3, image 1 of 1
      • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    2. Sony VAIO PCG-933A Fan Replacement: step 4, image 1 of 2 Sony VAIO PCG-933A Fan Replacement: step 4, image 2 of 2
      • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
      • This will release the speaker grille.
      Ask FixBot
    3. Sony VAIO PCG-933A Fan Replacement: step 5, image 1 of 1
      • Flip the computer so the key board is facing up.
      Ask FixBot
    4. Sony VAIO PCG-933A Fan Replacement: step 6, image 1 of 3 Sony VAIO PCG-933A Fan Replacement: step 6, image 2 of 3 Sony VAIO PCG-933A Fan Replacement: step 6, image 3 of 3
      • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
      • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
      Ask FixBot
    5. Sony VAIO PCG-933A Fan Replacement: step 7, image 1 of 3 Sony VAIO PCG-933A Fan Replacement: step 7, image 2 of 3 Sony VAIO PCG-933A Fan Replacement: step 7, image 3 of 3
      • Remove the 4mm screw in the center using a Phillips screwdriver.
      • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
      • The keyboard can now be removed.
      Ask FixBot
    1. Sony VAIO PCG-933A Fan Replacement, Fan: step 8, image 1 of 3 Sony VAIO PCG-933A Fan Replacement, Fan: step 8, image 2 of 3 Sony VAIO PCG-933A Fan Replacement, Fan: step 8, image 3 of 3
      • Remove the four 4mm Phillips screws around the hard drive.
      • WARNING: DVD drive is now loose as well
      • Carefully lift the hard drive cage out.
      • Carefully disconnect the copper strip to pull out the hard drive.
      Ask FixBot
    2. Sony VAIO PCG-933A Fan Replacement: step 9, image 1 of 2 Sony VAIO PCG-933A Fan Replacement: step 9, image 2 of 2
      • With the hard drive removed, unscrew the four 6mm brass colored, Phillips screws under the hard drive cage.
      • This will allow you to remove the hard drive mounting bracket.
      Ask FixBot
    3. Sony VAIO PCG-933A Fan Replacement: step 10, image 1 of 1
      • Remove the three 6mm brass colored, Phillips screws that hold the fan cage in place.
      Ask FixBot
    4. Sony VAIO PCG-933A Fan Replacement: step 11, image 1 of 2 Sony VAIO PCG-933A Fan Replacement: step 11, image 2 of 2
      • Remove the two 4mm black, Phillips screws shown here.
      • Remove the 18mm silver, Phillips screw shown here.
      • Now remove the silver tab.
      Ask FixBot
    5. Sony VAIO PCG-933A Fan Replacement: step 12, image 1 of 2 Sony VAIO PCG-933A Fan Replacement: step 12, image 2 of 2
      • Remove the blue and red fan power cords.
      Ask FixBot
    6. Sony VAIO PCG-933A Fan Replacement: step 13, image 1 of 2 Sony VAIO PCG-933A Fan Replacement: step 13, image 2 of 2
      • Carefully pull up and out on the metal heat sink and fan bracket.
      • The fan can now be cleaned or replaced.
      Ask FixBot
Sara Lillard
165 Reputation
8 Guides authored
Cal Poly, Team 12-36, Maness Spring 2011 Member of Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 109
All Time: 3,033
