Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓Repairing/replacing the DVD drive.
Tools
Turn the laptop upside down so that the top is sitting on a flat surface.
If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive.
Carefully remove the copper wire strip.
